Crankcase Sealant..Which One
Hobbit210
Mon Feb 06, 2012 1:11 pm » Post: #1 » Download Post
Which is the most reliable, and available, gasket sealant to use when rebuilding my NSR..and my YPVS
Thanks in advance
Mike
Harryredchow
Mon Feb 06, 2012 1:41 pm » Post: #2 » Download Post
Threebond.
Hobbit210
Mon Feb 06, 2012 2:23 pm » Post: #3 » Download Post
Harryredchow wrote:Threebond.
Thanks
Spoke to Patrick here:
P Seager Engineering
Unit A3 holywells Road Industrial Estate,IPSWICH,IP3 0DL
VERY helpful indeed.
Mike
Harryredchow
Mon Feb 06, 2012 3:21 pm » Post: #4 » Download Post
1104 is the stuff I used when I changed my crank.
Dmitry
Mon Feb 06, 2012 4:16 pm » Post: #5 » Download Post
I use Honabond for everything, like the results and consistency of the sealer when liquid.
1104 or threebond, Yamabond seem to be very similar, but not as runny.
Hobbit210
Mon Feb 06, 2012 6:24 pm » Post: #6 » Download Post
Apparently Three Bond make sealants for many motorcycle companies.
MIke
TuckerBag
Mon Feb 06, 2012 6:46 pm » Post: #7 » Download Post
toneless
Tue Feb 07, 2012 1:14 am » Post: #8 » Download Post
Threebond 1207B hasn't failed me yet and is excellent for modern crankcases.
Threebond 1104 is a cheaper alternative and does good work when joint surfaces are worn or uneven but I believe is now discontinued due to lead content?
2t-racelab.com
Wed Feb 08, 2012 6:04 pm » Post: #9 » Download Post
1207B is the stuff Honda spec, it's not cheap but the amount you use is so small I fail to see a reason to use anything else.
anonymous.shyster
Thu Feb 09, 2012 8:58 am » Post: #10 » Download Post
I used ThreeBond 1211 on both my car cylinder head and the NSR crankcase. I've got to do more driving and riding before I'll make a recommendation, however.
Dmitry
Thu Feb 09, 2012 1:44 pm » Post: #11 » Download Post
I resealed the dreaded camshaft/rocker box oil leak on my KTM with Hondabond, already lasted longer than factory KTM sealer.
Reading thumper forums it was the most recommended sealant for the job, even KTM shops recommend it Smile
