Dynojet dyno
Neal
Dynojet dyno
Thu Jan 05, 2012 5:42 pm » Post: #1 » Download Post
Hi , how do the people rate a dynojet dyno ? I know every dyno gives a different reading but am i correct to say that 1 dynojet dyno will give a very good comparison to another dynojet dyno elsewhere ? I have read some other info where guys say you add or subtract x% to compare a dynojet to something else . What is correct ?
anonymous.shyster
Fri Jan 06, 2012 2:56 am » Post: #2 » Download Post
My 300 got 65 Dynojet horses. After getting the jetting better than the dyno operator I'm sure I was getting a few more. Sure felt like it.
Neal
Fri Jan 06, 2012 5:14 am » Post: #3 » Download Post
Thanks for the info but i am really interested in the comparisons between dynojet and others . Is it safe to say that all dynojets are the same ?
Would you post your graph up ?
cheers
2T Institute
Fri Jan 06, 2012 8:12 am » Post: #4 » Download Post
Depends a lot on where the weather station is placed and the correction factor used.
RichG
Fri Jan 06, 2012 9:20 am » Post: #5 » Download Post
Some interesting reading here http://www.factorypro.com/dyno/true1.html
Look for 250cc street and race bike results section (and the 125 2T's).
But these guys appear to be claiming that all dynojet dyno results are > actual rwhp.
I don't know enough about dyno work to comment, but interesting looking at all the results anyway.
Rich
Harryredchow
Fri Jan 06, 2012 1:20 pm » Post: #6 » Download Post
I dyno should be used for back to back comparison or setting up with the baike under load. The values you get out should be taken with a pinch of salt. Never try to compare two dynos, or even the same dyno on 2 different days.
2T Institute
Fri Jan 06, 2012 1:59 pm » Post: #7 » Download Post
That is merely your engine NOT the dyno. Cold case figures(usualy one of the first 3 runs) are normaly the highest number.
A dyno is very useful tool, if you run gearing that approximates the time between gear changes you get accurate EGT readings.
A hell of a lot can influence the reading, tyre type and pressure, etc etc. The reading isn't a reading at the wheel it is a reading at the drum
