I have one of my fork tubes a bit curved and damaged. A good friend, has a brand new set of NC30 tubes. My plan was to swap my damaged tubes ( both ), for the new ones, using all the internals and parts of my fork ( MC21 SP fork ).
Both tubes ( MC21 & NC30 ) seems pretty similar, same diameter, same shapes all the way, the only difference is the total length, the MC21 ones are 16mm longer.. Due to that difference, the small hole at the bottom of the tube, it's also 16mm higher.
¿ Can i swap them without problems ?
I have search and read in the forum, but seems to be different NC30 forks, and i'm in doubt.
I attach two images, so you can see the difference.
