KmH - MPH mechanical converter
nobby62
Tue Aug 30, 2011 9:34 pm » Post: #1 » Download Post
Anybody using one of these on their NSR?.... there looks to be plenty of room to fit one and its got to be better than sticking numbers on the clock....... I'm thinking of buying one...
Tue Aug 30, 2011 9:41 pm » Post: #2 » Download Post
Had one on one of mine and it worked fine. Blue is I remember.
Tue Aug 30, 2011 9:56 pm » Post: #3 » Download Post
Yep, got mine from Wemoto and it works a treat
nobby62
Tue Aug 30, 2011 10:02 pm » Post: #4 » Download Post
Yep I've seen a blue one on t'internet....... Thanks for the replies, I'll order one Very Happy
dunkenb
1989 Honda NSR250 MC18
Tue Aug 30, 2011 10:35 pm » Post: #5 » Download Post
Got one on mine too Laughing
nobby62
Sat Sep 03, 2011 8:14 am » Post: #6 » Download Post
fitted it this week... seems to work ok (maybe a bit juddery at low speed...), not checked it for accuracy yet but seems pretty close....
Sat Sep 03, 2011 2:21 pm » Post: #7 » Download Post
I don't recall Steve's on the MC18 ever being juddery.
Make sure the cable's seated and routed correctly, and also free turning in the sleeve. There's obviously gearing inside the converter, but I don't expect there to be too much, if any slack/play in it, so the drive should be smooth.
nobby62
Sun Sep 04, 2011 10:15 am » Post: #8 » Download Post
Yeah I think i'll take it off and just check to make sure its seated properly etc.... cheers.
Sun Sep 04, 2011 10:30 am » Post: #9 » Download Post
Have a look at the speedo sprocket drive. Its a white plastic socket that drives the speedo unit. They often wear and give odd speedo readings.
nobby62
Sun Sep 04, 2011 10:32 am » Post: #10 » Download Post
Thanks Stephen, will do....
dunkenb
Sun Sep 04, 2011 4:42 pm » Post: #11 » Download Post
On some of the vfrs they use a metal one which is harder wearing. I had to change my plastic one as the cable kept spinning inside it? Cool
pvan340
Mon Sep 05, 2011 9:07 am » Post: #12 » Download Post
dunkenb wrote:On some of the vfrs they use a metal one which is harder wearing. I had to change my plastic one as the cable kept spinning inside it? Cool
Yep. Done that to two of mine. 20+ year old plastic and heat/revs. What model vfr? I asssume its a straight fit?
