Some help needed. No spark!!
eduk
Thu May 05, 2005 9:37 am » Post: #1 » Download Post
hi all,
my 1988 NSR 250 MC16 has started only running on one cylinder.
Im not getting a spark at the lower plug. Ive tried all the usual things, and ive swapped over the coils to check its ok, and they are.
So i guess the problem lies between the CDI and the spade plugs for the coil.
Has anyone got any ideas or suggestions? i dont like the idea of tracing those wires back....Sad
help please!
fstnsr
Thu May 05, 2005 10:50 am » Post: #2 » Download Post
have u tryed a new plug. i had a problem with my lower cylender and it was just the plug i changed everything exept it Rolling Eyes and the plug was just to wet so it was shorting rather than sparking.
eduk
Thu May 05, 2005 11:23 am » Post: #3 » Download Post
yes ive tried a few different plugs.
btw, is the CDI unit under the little compartment with the plugs and connectors at the top of the frame?
fstnsr
Thu May 05, 2005 11:38 am » Post: #4 » Download Post
on a mc 16 no that is for power valves. they are under the tank under the little black tray that has all the conectors and power valve servor on it.
jeff350lc
Fri May 06, 2005 8:52 am » Post: #5 » Download Post
the MC16 has a cdi for each cylinder and they do pack up. try swopping the cdi,s over.
eduk
Mon May 09, 2005 9:27 am » Post: #6 » Download Post
um i think there is just one CDI unit in my bike. Which has a connection on each side for each coil .
ive spent alot of time on this, and i thought i had narrowed it down to the plug on the cdi, for my lower cylinder, but by the time i had put the petrol tank back on, the spark had gone.
It seems very intermitten. Is it safe to swap the 2 plugs on the CDi unit round, so i can narrow the problem down.
ANy ideas please.!!
fstnsr
Mon May 09, 2005 9:47 am » Post: #7 » Download Post
it may look like one but it is two. they are in a rubber sleve. you can pull them out and change them round to check the spark.
eduk
Mon May 09, 2005 11:18 am » Post: #8 » Download Post
ahh, yes. now you say it, i can see that there are 2.! duh!
so now i can at least swap them round to check.
Another thing, the guy i bought the bike off, gave me a wiring diagram for a mc18, but the bike is mc16. How can i tell what wiring loom is in my bike? i think he may have done some mods to it, so possibly hes put a later loom in.
btw, anyone selling a CDI unit? in case it is my problem....
fstnsr
Mon May 09, 2005 8:46 pm » Post: #9 » Download Post
if it has the two cdi's its a mc16 coz the mc18 has a single cdi called a pgm1 and then they go up with the models to pgm4. the mc 18 digram i would think is use-less but here is a mc 16 one u can download
http://www.dreamgate.ne.jp/nsr/service%20manual/wiringdia/mc16wiring.html
