Running RS plugs
anonymous.shyster
Running RS plugs
Wed Jun 29, 2011 8:37 am » Post: #1 » Download Post
I just picked up some very well priced RS plug caps. Two!
I am wondering, what is the advantage (besides clearance) in running the RS plugs?
bandit_7
Wed Jun 29, 2011 9:19 am » Post: #2 » Download Post
Weight reduction. Just imagine the lap times.
You don't need both do you?
I just bought the HRC hose off JA. Just need the head you sold to someone else, plug and plug cap to complete the works. Wink
Bandit7
anonymous.shyster
Wed Jun 29, 2011 10:08 am » Post: #3 » Download Post
Wouldn't I get extra cred or poser points if I ran TWO rs plugs?
bandit_7
Wed Jun 29, 2011 10:18 am » Post: #4 » Download Post
anonymous.shyster wrote:Wouldn't I get extra cred or poser points if I ran TWO rs plugs?
Not from me!!! Laughing
Seriously though, I'm pretty sure they are just shorter.
Bandit7
Wed Jun 29, 2011 10:46 am » Post: #5 » Download Post
They offer a cleaner/sharper spark than the BR9ECM plugs, if my bench test is anything to go by.
But, if my bench test is anything to go by then you all really need to be running RS coils too. Stock coil and plug was like a birthday cake candle, whereas the RS coil and plug combination was like a lighthouse.
anonymous.shyster
Wed Jun 29, 2011 11:05 am » Post: #6 » Download Post
What was stock coil and RS plug like, then?
Hmm, RS coils... Sounds expensive. Done a dyno comparison?
mighty max
Wed Jun 29, 2011 1:40 pm » Post: #7 » Download Post
IS there any pro & cons using this?..
Any damaged to the CDI or the valve since the ignition is strong?
toneless
Wed Jun 29, 2011 3:05 pm » Post: #8 » Download Post
mighty max wrote:Any damaged to the CDI or the valve since the ignition is strong?
The CDI doesn't care what you do with the signal it provides,
you will have no issues with your PGM unit running rs plugs, coils etc.
2t-racelab.com
Neal
Wed Jun 29, 2011 4:46 pm » Post: #9 » Download Post
The rs plugs should resist missfires as the fine tip electrode concentrates the spark beter . I have converted to rs coils , wiring , flywheel etc . Dyno on the weekend !
Wed Jun 29, 2011 6:49 pm » Post: #10 » Download Post
anonymous.shyster wrote:What was stock coil and RS plug like, then?
It works, my bike runs and doesn't misfire ever. If you can muster the muscles to turn the rear wheel with it in gear it fires up on the paddock stand. Unlike my other bike if you try to start it by standing behind it and pulling a spoke round you'll lift it off the stand!
It's on a RS PGM, cut down mc18 loom, normal NSR charge circuit, reg-rec and battery, NSR coils, NGK TRS1408F shorty plug caps, NGK R5300A-95 plugs which are the 9.5 version of the R5300A-10 stock NF5 RS plug. 50/50 Avgas/unleaded
The 10's will work on the road (as will the 10.5's) but they'll foul easily and they'll never get hot enough to burn the insulator clean enough to get a good reading from a plug chop.
I've seen a few R5300-9 plugs, they're the ones you really want on a roadbike.
If you can find them the 9's and the 9.5s tend to be cheaper as well as the better choice for anything less than a GP bike.
cangus
Wed Jun 29, 2011 9:15 pm » Post: #11 » Download Post
I am very interested in learning the dyno results using rs coils and plugs vs. nsr.
MC21R9N track
MC18R2J track
CBR954
CR250
anonymous.shyster
Wed Jun 29, 2011 11:44 pm » Post: #12 » Download Post
+1
Thu Jun 30, 2011 3:19 pm » Post: #13 » Download Post
bear with me,i have the i factory coils and rs plugs/caps,i will let you know how it goes when its up and running Wink
mighty max
Thu Jun 30, 2011 11:21 pm » Post: #14 » Download Post
I'm very interested in the RS plung caps & coil. So where can I get it or anyone here willing......
anonymous.shyster
Sat Jul 02, 2011 9:10 am » Post: #15 » Download Post
silikesguiness your bike is perpetually in bits, isn't it?
I don't think we're going to get an answer to this, as I've searched the forums and there are two other threads dealing with this. A couple of people did the mod, and were going to post as soon as they'd put it back together. Guess what never happened?
