Oil Pump Problem
petralism
1993 Honda nsr 250 mc21 sp
Oil Pump Problem
Fri Jun 10, 2011 6:42 am » Post: #1 » Download Post
Today I finish my nsr 250 mc21 se restoration project I have oil pump no premix and i check oil pump doesnt sent oil! Oil is coming in the oil pump but from the other side nothing, i remove carburetor hoses to check and no oil coming. What could happened please give me some ideas to check it!
Before one moth when i start restoration it was working!
nsrdownunder
Fri Jun 10, 2011 10:48 am » Post: #2 » Download Post
The easy way to check if oil pump works is to take it out hook it up to a drill and spin with oil tanks still connected see if oil comes out . If not the would be lots of people on here with one they would sell.
petralism
Fri Jun 10, 2011 10:54 am » Post: #3 » Download Post
the oil pump was working before restoration i am thinking to try one more bleeding.when i do pump bleeding and remove the screw the engine must work ?
nsrdownunder
Fri Jun 10, 2011 10:56 am » Post: #4 » Download Post
I would do the drill way is safer then running the motor to blead it
toneless
Fri Jun 10, 2011 1:21 pm » Post: #5 » Download Post
It needs it's time before you can see oil at the end of the pipes.
You can fill the tank with about half a liter of fuel running in premix or fill the oil pipes with a syringe.
Using clear pvc pipes helps a lot as well.
2t-racelab.com
petralism
Fri Jun 10, 2011 5:50 pm » Post: #6 » Download Post
I remove the bleed screw and it has air inside so i left it to bleed then I reconect the screw and oil come out!
I do all these with premix so i was sure Smile
thank you guys Very Happy
petralism
Fri Jun 10, 2011 9:36 pm » Post: #7 » Download Post
One more question now I run premix and I disconect the 2 feed pipes from carburator to see oil flow I turn with my hand the pump puley full and every 3 sec bleeds. it is normal or low?
petralism
Fri Jun 10, 2011 9:54 pm » Post: #8 » Download Post
when it is in idle it doenst drop
