water pipe in barrel
javes
Sat May 28, 2011 2:06 pm » Post: #1 » Download Post
Finally got my barrel replated. Looks very tidy and clean
I received the water pipe in a separate box. Since this is a potential leak point, how should I assemble it? Dry? Silicone? Is it a press fit?
Thanks
Mon May 30, 2011 4:53 am » Post: #2 » Download Post
Epoxy that puppy back in there.
I believe that StephenRC45 has turned up some rather lovely waterpipes in the past so maybe he can assist if it all goes wrong.
pbekkerh
Mon May 30, 2011 10:21 am » Post: #3 » Download Post
I have the same worry. Were they not inserted dry originally ?
If you epoxy them in, can you get them out next time you need to nicasil the cylinders ?
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
pbekkerh
OT: why does the reply screen get 4 meters wide ??
Mon May 30, 2011 10:25 am » Post: #4 » Download Post
When trying to reply here, I get a screen about 20 screens wide to the right and have to scroll at least 10 screens to find the submit button !!
Poul
MC21SE, KISS box
toneless
Mon May 30, 2011 1:26 pm » Post: #5 » Download Post
Press fit with a little bit of Loctite thread sealant.
2t-racelab.com
javes
Mon May 30, 2011 2:25 pm » Post: #6 » Download Post
I sent the barrel for replating with the tube inserted, and received it with the tube removed, so I do not know how to remove it. I see that the tube is immaculate, no scratches, no rests of sealant/glue in the length that sits inside the barrel. The other portion is slightly corroded, so I assume that's where it is wet.
I'll cool the tube before inserting it with some loctite/epoxy all arround and check that it doesn't move when pulling by hand. Will report results.
javes
Sun Jun 12, 2011 10:28 am » Post: #7 » Download Post
So I inserted it cold, but it has not been sufficient.
I fired it up yesterday and run the first heat cycle, there was a small leak. This morning I rode it for the first time and in 2 min, the water pipe became loose and all liquid was lost. As I am wearing shorts and have no fairing, it took me 1 sec to stop and call for a tow vehicle.
The bore in the barrel has a ridge that los like it does the sealing, but I think the tube needs to be glued somehow.
Anyway, the engine febles strong up to 7-8k.
Harryredchow
Re: OT: why does the reply screen get 4 meters wide ??
Sun Jun 12, 2011 10:37 am » Post: #8 » Download Post
pbekkerh wrote:When trying to reply here, I get a screen about 20 screens wide to the right and have to scroll at least 10 screens to find the submit button !!
Are you running Internet Explorer 6 by any chance?
pbekkerh
Sun Jun 12, 2011 1:40 pm » Post: #9 » Download Post
hehe, It was IE8 but now IE9 and the page adapts ok to my screen.
Poul
MC21SE, KISS box
{.bLanK}GoD
Mon Jun 13, 2011 10:04 am » Post: #10 » Download Post
javes wrote:I am wearing shorts......................
Tisk tisk.
Mon Jun 13, 2011 10:16 am » Post: #11 » Download Post
Tisk tisk.
When we got our first NX5 it came in bits. By the time I'd put it together it was just getting dark. I took it for a spin up and down the Sukhumvit highway (in shorts and T-shirt) and declared it "good fun but a pain getting away from the lights". Paul was itching for a go, so off he went (shorts and T-shirt), but it was now dark. He did a couple of high speed runs but kept getting his flip flop tangled up in the gear lever, and the mosquitoes were getting in his eyes.
Thailand.......tisk tisk.....
javes
Mon Jun 13, 2011 1:07 pm » Post: #12 » Download Post
Tisk tisk.
You are absolutely right. It's no excuse but I was (a) working on the bike and did not intend to ride it (b) only foing next block for petrol (c) too anxious to check for leaks (d) whatever other silly reason
I happily returned home on the breakdown lorry, with an empty cooling circuit.
I am going to try Loctite 641.
imdying
Mon Jun 13, 2011 10:58 pm » Post: #13 » Download Post
Matt@TYGA wrote:kept getting his flip flop tangled up in the gear lever
Lmao Laughing
