oil pump purge
fovu
oil pump purge
Fri Mar 25, 2011 11:55 am » Post: #1 » Download Post
hi
i want to change the oil the previous owner was using on my bike,i was wondering if i need to purge the lines or if just emptying out the tank and refilling it is good enough?also does the pump need to be primed in any way after removing the oil lines to the carb?
dunkenb
1989 Honda NSR250 MC18
Fri Mar 25, 2011 4:19 pm » Post: #2 » Download Post
There's an air bleed nut on the top of the oil pump think its shown on the workshop setion on setting up the oil pump . Very Happy
fovu
Fri Mar 25, 2011 9:59 pm » Post: #3 » Download Post
i looked at that section but it only shows you the marks to line up to for setting the pump
pvan340
Sat Mar 26, 2011 4:24 am » Post: #4 » Download Post
http://www.nsr-world.com/workshop/rebuild/rebuild-5.php
Gives some good info
fovu
Sat Mar 26, 2011 8:03 am » Post: #5 » Download Post
thanks,that is what i need
