rear shock compatibility
NSR-LOVER
Fri Mar 04, 2011 10:44 am » Post: #1 » Download Post
Hi!
I want to get rid my old rear shock it is ''R'' speq and i have an mc21.
What choises do i have except the sp speq ones?
I mean is there any other that fits? dont want to give a fortune for some new ones...
thanks!
NSR-LOVER
Sat Mar 05, 2011 7:27 pm » Post: #2 » Download Post
anyone? has anyone fitted from cbr600f4i?
nxrsr20
Sat Mar 05, 2011 9:01 pm » Post: #3 » Download Post
Dimension wise the shock is a bit longer and I think the spring rate is a bit higher. The reservoir hose fitting coming off the shock body fouls against the frame bracing.
NSR-LOVER
Sat Mar 05, 2011 9:40 pm » Post: #4 » Download Post
You re right it seems that i must find one which the reservoir hose fitting coming off the shock body exits like the stock sp ones...
NSR-LOVER
Sat Mar 05, 2011 10:12 pm » Post: #5 » Download Post
is there any chance this style: http://www.safaricycle.com/wp-content/uploads/2010/07/116.jpg could fit?? if not then only like the sp ones.
dunkenb
1989 Honda NSR250 MC18
Sat Mar 05, 2011 10:21 pm » Post: #6 » Download Post
Think it's the 1993 ish cbr600 one that fits.
NSR-LOVER
Sat Mar 05, 2011 10:46 pm » Post: #7 » Download Post
Well if we had lots of money to spend then it would be really fun!
I compared some pictures and it seems that f3 and f4 cbr shocks are the same in terms of hose exit!
NSR-LOVER
Sun Mar 06, 2011 4:07 am » Post: #8 » Download Post
can someone who has a shock out measure these spots from an mc21/28, se/sp rear shock? http://img851.imageshack.us/i/rearshockoverview.jpg/
It would be much appreciated!
dunkenb
Sun Mar 06, 2011 9:05 am » Post: #9 » Download Post
F3 the length C = 290mm the bottom shock mount is the same as nsr's but the top mount needs about 2mm removing from the width. I just took one out of my mc18 and replaced it with the standard one. Found it too stiff, couldnt get any static sag! Was going to put the nsr spring in the cbr body, but no bike shops where i live in the sticks had a proper spring compressor! Very Happy
NSR-LOVER
Sun Mar 06, 2011 11:24 am » Post: #10 » Download Post
Thanks! that means that the f3 youve got doesnt fit to the mc21/28 due to short length...
I believe the cbr 900rr is the best bet cause it has same lenght (at ohlins catalogue).
unfortunately the ohlins catalogue doesnt have any specs for the f3-f4 cbr's so we must find by asking...
