Bodywork - help
Jeff B
Bodywork - help
Wed Apr 21, 2004 8:18 am » Post: #1 » Download Post
Hi All
Have aftermarket pipes on MC28 that take up more space than stock, hence stock lowers don't fit. Am taking a blade to the inner sections of the air ducts to give more space and reduce the smell of hot plastic but is there more space inside the Tyga stock shaped lowers or can you come up with another solution? Apart from the look and the sound and the supposed performance gain I am getting annoyed with myself for buying the new chambers in the first place
Ring-a-ding-ding Rolling Eyes
Oh No, It's raining again......
Wed Apr 21, 2004 8:55 am » Post: #2 » Download Post
Don't be! Stock pipes are pants. I used a small block of wood painted black to space out the right hand fairing just below the footrest. Made the race scrutineers chuckle... Wink
Wed Apr 21, 2004 8:59 am » Post: #3 » Download Post
Well, Dave beat me to it!! (I saw he was browsing the Forum too - I should've known!)
Usually a 10mm spacer is enough, plus all the mountings on the frame can be loosened and wiggled around a little to move the bodywork about a bit.
As he says, the stock pipes are shocking! Get the jetting set up correctly and the race pipes will be worth their weight in HP!! :)
Jeff B
Wed Apr 21, 2004 9:05 am » Post: #4 » Download Post
Thanks Guys. Looks like another evening in the garage (much to my wife's annoyance!) Rolling Eyes
lukeh
Bodywork - help
Wed Apr 21, 2004 9:23 am » Post: #5 » Download Post
Do Tyga SS Pipes suffer these same or other clearance problem's on MC28 ???
Wed Apr 21, 2004 10:33 am » Post: #6 » Download Post
All aftermarket pipes will I suspect, as the chambers are designed for power and therefor end up in the way. Honda didn't want max power, so could route them for cosmetics instead.
lukeh
Bodywork-help
Thu Apr 22, 2004 6:38 am » Post: #7 » Download Post
Thanx Dave Ett for your reply ...But at this point , I'm looking for specific examples of the combination I mentioned . I thought Honda deliberately restricted the Power Output of these bikes in accordance to suit manufacturing Law's in Japan at that time ???
Thu Apr 22, 2004 7:02 am » Post: #8 » Download Post
Yes they did, which is why the shape of the pipe for power wasn't as important as the routing. Wink
Thu Apr 22, 2004 8:10 am » Post: #9 » Download Post
To develop full power, the expansion chambers need to be "fatter" than the stock Honda pipes, and also shorter.
This means that any race pipe you fit will be too wide to fit inside the stock (or stock pattern) bodywork.
Some aftermaret designs, notably TYGA Performances GP250 fairing and Jha's latest range, will accommodate race pipes as it was designed around them.
I believe TYGA pipes and HARC Pro pipes are the worst for fitting because they are the fattest (i.e. most developed!) pipes on the market today. TYGA's GP pipes were only released 18 months - 2 years ago, and were built from scratch using the latest TSR software available at the time, so you won't find much better performance! A slight adjustment of the bodywork to fit pipes like these is well worth the effort, and will transform the bike in both power delivery and looks!
