MC18 engine compatability
gammaguy21
Thu Nov 18, 2010 8:25 am » Post: #1 » Download Post
I'm trying to find spares for my R2/4J mc18.
Will the bottom ends of a RK5 or RK6 work with the R2/4J wire harness?
I understand that there are differences in the ignitiion, but just trying to see if other model mc18 engines will work with what I have.
I have searched and have almost read / skimmed all the 245 threads in the discussion forum and don't remember coming across any info.
Thu Nov 18, 2010 9:40 pm » Post: #2 » Download Post
I can't see any reason why there would be a problem. There may be a slight difference with the stator or pickup plugs but as you have the old plugs you'd be able to fix that anyway.
geezagillard
Sat Nov 20, 2010 8:41 am » Post: #3 » Download Post
Yeh I agree....I put an MC21 bottom end into a PGM1 88 NSR and I remember using the MC18R2 pick ups and flywheel so worth checking with the R5/R6.
I think I also had to find the neutral wire within the GPS but I'm not sure you will have to deal with this using the R5/6 PGM2?
gammaguy21
Wed Nov 24, 2010 2:03 am » Post: #4 » Download Post
Great!
Thanks for the info guys.
Wed Nov 24, 2010 9:53 am » Post: #5 » Download Post
geezagillard wrote:I think I also had to find the neutral wire within the GPS but I'm not sure you will have to deal with this using the R5/6 PGM2?
Correct, the GPS is only on the mc21, all other NSR road loom's just have a neutral sensor.
