nsr 250 mc18 r5k - need clutch cable & gear linkage
sboyd
Sun Oct 17, 2010 9:12 pm » Post: #1 » Download Post
Hi all. this is my first post on this forum, so bear with me if I mess up. I just took delivery of an 89 nsr250 r5k and upon inspection of the bike I need a new clutch cable and the gear change linkage piece that attaches to the splined gear change shaft. If anyone can help I would appreciate it. I live in Ireland and NSR's are a very rare species over here.
PS On inspecting the bike I noticed "PJ280" stamped into the side of the barrels - does anyone know if this means anything ? Thanks
Sorry I now realise I should have posted this in classifieds- oops!!!
dunkenb
1989 Honda NSR250 MC18
Sun Oct 17, 2010 9:29 pm » Post: #2 » Download Post
if the bit that clamps around the output shaft is loose you can file in between the two parts of it to widen it to tighten it up??
sboyd
Sun Oct 17, 2010 9:36 pm » Post: #3 » Download Post
Thanks -thats exactly the story. The clamp bolt head had sheared off leaving the clapm to float on the shaft (probably for years) and this has worn the splines smooth on the clamp. Will try your suggestion but would prefer to replace it if anyone has one. Thanks.
Sun Oct 17, 2010 11:09 pm » Post: #4 » Download Post
You can still get them new from Honda. There was a post on here just recently (last week, I think) with the part number.
javes
Mon Oct 18, 2010 9:06 am » Post: #5 » Download Post
I had issues with the gear change, as it was not very precise. I found that the bolt that clamps the gear linkage that is referenced here was tightend until it contacted the linkage, but I needed to keep on tightening it real hard so that there was an effective clamp effect on it. It now works OK.
nsrjb
Mon Oct 18, 2010 11:12 pm » Post: #6 » Download Post
i have a spare one if you want you can have it for a tenner.
i am from west cork.
nsrjb
Wed Oct 20, 2010 1:53 pm » Post: #7 » Download Post
just checked the part there it is damaged the threaded piece that connects to gear change rod is cracked sorry.
sboyd
Wed Oct 20, 2010 2:53 pm » Post: #8 » Download Post
No problem thanks
Wed Oct 20, 2010 4:07 pm » Post: #9 » Download Post
Again, the part is available new... and it's not expensive.
sboyd
Wed Oct 20, 2010 4:11 pm » Post: #10 » Download Post
Thanks,
I have ordered the part from Honda.
