Leaking transmission , can I weld it?
gavster
Wed Sep 08, 2010 7:34 am » Post: #1 » Download Post
Hi I have a mc18 . payed a guy (cowboy) 7months later. Comes back with crack so small in transmission ,leaks bad. took ages to find , can this be welded, or is it an alloy that can be welded.Do i need a whole new case?
crank case has leak
bandit_7
Wed Sep 08, 2010 8:08 am » Post: #2 » Download Post
Tig weld it. Would take 5 seconds.
Bandit7
Middo
Wed Sep 08, 2010 8:23 am » Post: #3 » Download Post
Just out of curiosity, would the case suffer any distortion from welding? Would it have to be clamped flat along it's mating surface during the heating/cooling cycle?
I'm contemplating having some cases modified, and was just thinking of any possible implications.
bandit_7
Wed Sep 08, 2010 8:42 am » Post: #4 » Download Post
I wouldn't weld anywhere near a bearing surface or mating surface. It can probably be done with ease but I don't know. When tig welding stainless the parent metal pulls quite hard. Aluminium may be different but I'm not too sure, best ask a metallurgist or very competent welder.
bandit7
nxrsr20
Wed Sep 08, 2010 8:42 am » Post: #5 » Download Post
someone can shoot me down in flames, but could the metal putty stuff be used?
Otherwise you can always buy my MC18 crankcases that no one wants to buy! Rolling Eyes
gavster
Wed Sep 08, 2010 9:02 am » Post: #6 » Download Post
how much you want nxrsr20
80XAR
Thu Sep 09, 2010 10:02 pm » Post: #7 » Download Post
Ive seen a Nissan Primera gear box welded up that hit a brick. It had a decent chuck broken out of it.
Im sure a professional would able to weld it up no problems. There is a fella up here in bris that welded my chassis when it cracked. I can send you his details if you like.
