NSR/CR 500
Wrathfultalon
NSR/CR 500
Mon Sep 06, 2010 4:25 pm » Post: #1 » Download Post
interesting build i came across while searching for parts.
http://www.dreamgate.ne.jp/NSR/Project%20NSR/NSR500/500_main.html
Glen
Tue Sep 07, 2010 7:25 am » Post: #2 » Download Post
All that work and money thrown at it, for nothing!!
At least he had a go..
Paranoia about failure will ensure nothing but failure to ever reach potential.
MC18 Race bike project..
MC21 Race bike..
KTM39
2009 KTM 530 EXCR
Tue Sep 07, 2010 2:30 pm » Post: #3 » Download Post
The ending seemed like a bit of an anticlimax.
Surely he anticipated some major vibration?
I'm glad in a way - that exhaust was the ugliest thing I've ever seen.
80XAR
Tue Sep 07, 2010 10:07 pm » Post: #4 » Download Post
Yeah. He could of easily bent the pipe into a decent position instead of mounting it like a truck exhaust stack !!
He could of tried using softer rubber mounts to take some vibration out of it. That subframe might of been a cause for that. The NSR motor is a rubber mounted stressed member, and doesn't use a subframe at all.
Was good that he didn't sodimise the chassis though.
10/10 for effort still. I think it could be made to work better with some more refinement.
Wed Sep 08, 2010 1:51 am » Post: #5 » Download Post
The CR is a vibrating pig at the best of times. I loaded my CR500 engine into my CR250 aluminium chassis for Super Motard. Solidly mounted. No girly rubber bushes.
But the fact is Chris did it and the bike ran. Not perfect but a runner all the same.
And yes, the pipe is very ugly, but the 500 demands a very long pipe as it doesn't rev, and a huge body means you're very limited for space.
2T Institute
Wed Sep 08, 2010 10:03 am » Post: #6 » Download Post
Isn't that hard just have to know what your doing. Down pipes are a snack up pipes are the true test of a pipemakers skill Very Happy Very Happy Very Happy
Should check out some of Fedor Copal's work
Wrathfultalon
Wed Sep 08, 2010 11:25 am » Post: #7 » Download Post
i think the pipe is w0rth more then the bike!
pbekkerh
Thu Sep 09, 2010 6:40 am » Post: #8 » Download Post
Did you see the next CR500 project on that side ? that looks really professionnal, although I don't understand the need for a 1 cyl. 500cc.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
pvan340
Thu Sep 09, 2010 7:16 am » Post: #9 » Download Post
yeah, I've often thought about an NSR 500 project. Something like a one off case and crank, 90 deg V4 configuration naturally! Readily available bearings using CR 125 barrels, pistons and conrods/bearings. RS250 gearbox, CR500 clutch, or NSR dry clutch. 4 pickups on the flywheel and maybe a Motec M880 brain to control it all. Don't know about carbs or powervalves, what to use there! Anyway, its a prohibitivly expensive dream, but passes time on the daily train ride!
2T Institute
Thu Sep 09, 2010 7:37 am » Post: #10 » Download Post
Mick Costin recently sold a set of NSR 500 cases for $10k US. The rest except the 1 piece press up crank would be easy.
(Oh yes the 480 was completely restored, that cannot be ridden in first gear it digs trenches in tracks in a one mean man bike)
