NF5 Shock length
GrantA
NF5 Shock length
Mon Jul 05, 2010 7:57 pm » Post: #1 » Download Post
Hi does anyone have a NF5 rear shock they could measure the length of?
Mon Jul 05, 2010 8:38 pm » Post: #2 » Download Post
Moved to RS Discussion (copy left in NSR HRC) as you may get more feedback here.
GrantA
Tue Jul 06, 2010 8:06 pm » Post: #3 » Download Post
Andy wrote:Moved to RS Discussion (copy left in NSR HRC) as you may get more feedback here.
Thanks
GrantA
Wed Jul 07, 2010 7:59 pm » Post: #4 » Download Post
In another thread there is a mention of the nf5 rear shock being 33.5cm.
Anyone know if that length would suit the mc21?
Wed Jul 07, 2010 9:24 pm » Post: #5 » Download Post
How long is your '21 shock?
I can't remember how much taller my HRC is set, but adjuster is wound out to max, and I expect it's probably about +20~25mm.
Wed Jul 07, 2010 10:55 pm » Post: #6 » Download Post
The NF5 shock is 335mm in length. The NSR shock is 315mm.
The NF5 won't fit the NSR swingarm linkages as it uses a 'fork' type mount at the bottom, not an 'eye' type like the NSR.
A better bet is to fit an old CBR600 shock or an RS125shock as this is the right length and fittings. The big problem with the RS125 shock is the standard sub frame needs cutting to accomodate the reservoir.
Check out Si's MC21, he's had one fitted.
Good luck!!
GrantA wrote:In another thread there is a mention of the nf5 rear shock being 33.5cm.
Wed Jul 07, 2010 11:34 pm » Post: #7 » Download Post
May I draw your attention to this thread Tom?! Wink
http://nsr250.net/forums/viewtopic.php?p=70788#70788
Well ahead of you... just needed the shock length! Smile
GrantA
Fri Jul 09, 2010 12:58 pm » Post: #8 » Download Post
looking for a nf5 shock now to see if it can be converted. Trying the link you sent me Andy. Waiting for Moriwaki-man to get in touch about it.
