Power valve servo
MC 21 BRIAN
Power valve servo
Tue May 04, 2010 9:49 pm » Post: #1 » Download Post
Hi, fiddling with the power valves via the setting procedure on here and noticed that my servo doesnt go to the high position even with the cables slackened off. Is this normal . And no i still haven t got it running right yet. Crying or Very sad
Tue May 04, 2010 10:39 pm » Post: #2 » Download Post
Just to be sure, follow this procedure:
1. IGN on
2. RUN switch to RUN
3. IGN off
4. RUN switch to OFF
5. Disconnect TPS
6. IGN on
7. RUN switch to RUN (listen and watch servo closely!)
Does the RC Valve servo move?
If it doesn't you need to test the servo, the wiring, or your PGM on another bike! (It's not wise to test a working PGM on yours in case the servo or a short has blown it.)
A full fault-finding procedure is in the English Workshop Manual.
nsrdownunder
1993 Honda nsr 250 mc21 sp
Wed May 05, 2010 6:11 am » Post: #3 » Download Post
The servo on both my mc21`s dont go to the high mark i don`t think they are suppose to . The hrc method of doing them is to rev to 11000 i think and mark the servo when open .I think mine are about 3/4 to the high mark
Kubira
Wed May 05, 2010 7:52 am » Post: #4 » Download Post
hrc method does infact say >10000 rpms, however the easy way is to blip the throttle no more than 4k rpm's, and mark the highest point. youll notice it moves around a bit trying to keep the engine running
MC 21 BRIAN
Sat May 08, 2010 8:13 pm » Post: #5 » Download Post
Yes the servo moves and goes to about the three quarter distance which seems to be fine going by the replies. Have been having problems with it oiling plugs, their black as yer boot. Thing is i cant depend on it taking me far enough out of town to plug chop it without it breaking down. Runs rough between about 5 to 7 or so then pulls a lot better to the red line though not perfect. The novelty of pushing it from the bottom of a half a mile long steep hill wore of a while ago and as much as i love the thing its on thin ice.. Crying or Very sad
Sat May 08, 2010 8:19 pm » Post: #6 » Download Post
Well first off check the usual things...
Air filter clean
Oil pump set correctly
Jetting
Correct spark plugs
If it's proving difficult, I've often set them back to totally standard (inc wire-splice) and gone from there. A stock NSR carburetes perfectly across the entire rev-range, so if it's all stock and still won't work you know you have bigger problems.
nsrboy
Sun May 23, 2010 10:36 am » Post: #7 » Download Post
mine is stuck on hi all the time ignition off
Sun May 23, 2010 1:01 pm » Post: #8 » Download Post
It won't reset to Lo unless you disconnect the TPS or until the engine runs again... and won't reset if the PGM is knackered, or the cables are set up/adjusted incorrectly, or if the servo's dead...!
Not giving much to go on, are you?!
nelly
Tue May 25, 2010 10:06 pm » Post: #9 » Download Post
similar problem here as well on mc18 r2k,
when i turn the servo manually with the ignition is off and switch it back on, it sets to the low position. and when i start it and rev the bike it tries to turns past the low position and hits the stop when it should be moving towards the hi position. i have changed the servo, servo control unit and cdi. the only unit/box that i have not changed is on the opposite side to the cdi unit, it also plugs into the servo control unit.
it could be that unit that is broken but i dont know what it is?
i couldnt find it on my wiring diagram.
Wed May 26, 2010 7:47 am » Post: #10 » Download Post
Haven't got the cables swapped over have you?
nelly
Wed May 26, 2010 8:08 am » Post: #11 » Download Post
no, it,s the servo thats going the wrong way, even with the cables removed?
jeff350lc
Wed May 26, 2010 9:27 am » Post: #12 » Download Post
you've not got an MC16 servo on there have you?
Wed May 26, 2010 3:15 pm » Post: #13 » Download Post
Not actually that easy to fit an MC16 servo to a later model Jeff, but I see what you are thinking.
