nsr250rk5 mc18 ""help""
stevo
Sat Apr 16, 2005 1:37 pm » Post: #1 » Download Post
need help with this one big time only just got round to rebuilding engine after 10 months and just filled radiator up with coolant and for some reason its pissing out of the exhaust gasket on the bottom cylinder
have i not tighten somethink up maybe or has somethink come loose
do i need to strip out down to find then cure
Sat Apr 16, 2005 2:01 pm » Post: #2 » Download Post
Got to be a head gasket or a base gasket not seated correctly/torqued correctly, I would say.
Bit of a bugger that one. I guess the exhaust is off at the moment? If you fill the radiator, does the water litterally gush out of the exhaust?
stevo
Sat Apr 16, 2005 2:08 pm » Post: #3 » Download Post
thanx andy yeah water does gush out of the exhaust guess i made a mess of that then
ill have to strip the head off find out where the prob is
i guess it aint a big prob to sort afterall
will let u know
Andy wrote:Got to be a head gasket or a base gasket not seated correctly/torqued correctly, I would say.
Sat Apr 16, 2005 4:25 pm » Post: #4 » Download Post
Probably going to cost you about £15-20 in gaskets, but never mind.
Really closely inspect the barrel for any signs of cracks while it's all apart.
A light smear of liquid gasket on the each side of the base gasket won't hurt (well, until you need to get it off next time!!), but make sure the head gasket is used "dry" only.
If you wanted to be certain about the mating surfaces you could lap the head and barrel on a sheet of glass, but it's very rare that they are deformed.
stevo
Sat Apr 16, 2005 5:21 pm » Post: #5 » Download Post
lucky enough i got spare gaskets for it last year anyway
i can allways grab them off u now u got your own corner shop top prices aswell nice
i hope there aint no cracks in the barrels got them from tyga Laughing
well after alot of hassle of trying to borrow a torque wrench again looks like ill have to buy one
anyone recomend a Torque Wrench
