Gearbox oil
Neal
Gearbox oil
Tue May 11, 2010 6:05 pm » Post: #1 » Download Post
Hi guys ,any comments on Moyul gearbox oil vs Bellray gearbox oil . Thanks .
cgallant
2001 Honda RS250
Wed May 12, 2010 1:11 pm » Post: #2 » Download Post
Motul 300 is fine gear oil. I use it in my RS250.
KTM39
2009 KTM 530 EXCR
Wed May 12, 2010 2:53 pm » Post: #3 » Download Post
I can't comment on the specific oils you've mentioned, but I can say that Belray Thumper is about the best gearbox oil I've used, (even though it's an engine oil).
When I had my KTM525, (which has the normal engine oil setup running through the trans) I noticed that the gearbox was much smoother on Belray Thumper than the mega dollar Motorex fully synth 4 stroke oil.
I pulled the trans oil out of my RGV and put Belray Thumper in there, and again found a noticeable improvement.
I've heard some good things about the Motul oils, but I reckon they're overpriced. I prefer to run oils that are slightly less expensive, (not cheap) and change them more often.
