Dry Clutch Removal
Skunkbait
Dry Clutch Removal
Tue May 11, 2010 12:56 pm » Post: #1 » Download Post
What's the best way to remove the dry clutch on a 1991 SE model. I can't get the clutch tool (two steel rings welded to a handle) in there to hold the clutch hub.
Also, is there a good source to buy a clutch hub. Mine looks pretty beat up.
Thanks.
Skunkbait
Tue May 11, 2010 1:12 pm » Post: #2 » Download Post
I have sacrificed old clutch plates in the past (I now have a set for wet clutch and one for dry).
I used one metal plate and one fibre, drilled and bolted them together. That then holds the clutch together whilst you undo the centre nut.
Bodge and sorted.
Kubira
Tue May 11, 2010 1:22 pm » Post: #3 » Download Post
ive just put the bike in 3rd or 4th gear, and press the rear brake, crack the nut, and boom, undone
Tue May 11, 2010 1:42 pm » Post: #4 » Download Post
Kubira wrote:ive just put the bike in 3rd or 4th gear, and press the rear brake, crack the nut, and boom, undone
Might just work...... forgot to say the clutch/gearbox can be removed with the motor still bolted in the frame.
Skunkbait
Tue May 11, 2010 1:46 pm » Post: #5 » Download Post
Thanks for the advice. The motor is still in the frame. I thought it would be easier to remove the clutch while in the frame. That way I don't have to hole the motor still on a bench.
Can you still order NSR parts through a Honda dealer in the states?
Skunkbait
cgallant
2001 Honda RS250
Tue May 11, 2010 1:50 pm » Post: #6 » Download Post
ordering KV3 parts through honda dealers in the states is hit and miss (mostly miss).
Your best bet is to work with Craig @ Redline Powersports (http://www.redline-ci.com/)
Tue May 11, 2010 6:42 pm » Post: #7 » Download Post
Use this:
wrench
Whilst your bike is in gear, with a rag-wrapped stick through the rear wheel.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed May 12, 2010 1:55 am » Post: #8 » Download Post
Impact guns are for trucks.
I use a clutch holding tool.......which we just happen to have in stock.....
Wed May 12, 2010 11:17 am » Post: #9 » Download Post
Matt@TYGA wrote:Impact guns are for trucks.
Embarassed
