top end rebuild?????
nsrjb
Mon May 03, 2010 12:48 pm » Post: #1 » Download Post
i have compression readings of about 110 psi on both cylinders.
the bike drives fine but i dont think it has the same power it used to have.
do you think it is safe to keep riding with this amount of compression or should i get new piston rings???
Mon May 03, 2010 1:16 pm » Post: #2 » Download Post
Never hurts to sling a new set of rings in! I usually go through 2 or 3 sets of rings to a set of pistons, to give you a rough idea. (Usually 2 sets.)
Mon May 03, 2010 1:34 pm » Post: #3 » Download Post
It's always nice to change the rings.
If you remove the exhausts and have a look up the port you might be able to see some blow by past the rings. If you do then the rings would be worthwhile changing.
Mon May 03, 2010 1:37 pm » Post: #4 » Download Post
Especially when you only have one ring per piston, eh Steve... and even more so when it's only 0.4mm thick?! Laughing
Don't last long, do they?! Very Happy
Changed those in the F3 yet, since Llandow?!
Mon May 03, 2010 1:40 pm » Post: #5 » Download Post
I'll be changing mine tomorrow. No they don't last long and mine ran almost all day so they will be well worn out.
Deon
1990 Honda NSR250 MC21
Re: top end rebuild?????
Mon May 03, 2010 4:43 pm » Post: #6 » Download Post
nsrjb wrote:i have compression readings of about 110 psi on both cylinders.
I've just re-ringed my bike and measured 1000kPa (145psi) on each cylinder (at sea level). I think you should get a new set of rings. It will only make you smile Very Happy
