sp flashes on display when hrc card inserted
buzn
Sat May 01, 2010 9:39 pm » Post: #1 » Download Post
hi guys, my mc28 is a se however sp flashes on display when hrc card inserted...is this normal?
thefastmen
1995 Honda NSR250 MC28SE
Sun May 02, 2010 7:43 am » Post: #2 » Download Post
Yep my SE mc28 does the same thing Wink
Sun May 02, 2010 11:43 am » Post: #3 » Download Post
When an MC28 is derestricted using the HRC card, it flashes up SP in the dash, and then shows a large temp gauge where the speedo should be.
All is normal.....
Just one thing to note for those who've just about to install the HRC card for the first time, it that you need to leave it in the slot till the SP disappears off the screen. That about a minute.
Now I'm not sure if this is true, but I've been told that if you take the card out before it's run through this process, the card will not work again...... be warned.
diviCe
Sun May 02, 2010 12:25 pm » Post: #4 » Download Post
Yep, all normal...
It's Good to be Bad!
thefastmen
Sun May 02, 2010 1:41 pm » Post: #5 » Download Post
When I putted in the HRC030 card for the first time the SP sign disapered after 1 or 2 seconds.
diviCe
Sun May 02, 2010 1:43 pm » Post: #6 » Download Post
thefastmen wrote:When I putted in the HRC030 card for the first time the SP sign disapered after 1 or 2 seconds.
thats normal too...
thefastmen
Sun May 02, 2010 4:29 pm » Post: #7 » Download Post
I thought so to!!
I also feel the diference between the cards when I ride my 28
