Front Fork Bottom Cleaning
baron580
Tue Apr 20, 2010 1:06 am » Post: #1 » Download Post
My fork bottoms are in a right tatty state.
Can anybody tell me what's the best way to clean up the fork bottoms?
I'm thinking vapour blasting or maybe bead blasting but want to be sure.
Has anybody done this? If they have I'd sure welcome some advice on the best method available.
jayRC3045
Tue Apr 20, 2010 3:42 am » Post: #2 » Download Post
scotch bright and WD40 , go gentle with it and try it on the inside of the forks 1st to see what it comes up like as ive not done it on NSR forks ,but ive done it on some RC30 forks and they came up a treat
Dexter
Tue Apr 20, 2010 11:30 am » Post: #3 » Download Post
I ll be soda - blasting mine, in a few days. I ll put up pictures.
baron580
Tue Apr 20, 2010 8:10 pm » Post: #4 » Download Post
Hey Dexter, that would be great. I'd love to see how they turn out as there are a few places near me that do soda blasting although I think vapour blasting would probably give the smoothest finish and be less abrasive.
Dexter
Tue Apr 20, 2010 8:39 pm » Post: #5 » Download Post
In fact vapour blasting is a bit more aggresive, as it is some sort of acid in vapour form that is blasted onto the surface. It leaves the object "dry"and in need of immediate care. There is a thread about it in here, somewhere.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Wed Apr 21, 2010 8:55 am » Post: #6 » Download Post
Paul is a bit of an expert at this, but I'll try and explain how he does it.
Basically I think what you're after is a nice standard finish, so generally a bit of aggression with some wet & dry is called for to take out any nicks or dents. Done wet of course to keep the paper from clogging.
Once the marks are out, progress to finer paper. Once you're down to about #600 try then to only go around the fork lower, not up and down it. Do this until any and all 'up & down' marks have been removed.
Wash and dry the lower, and then grab a new new green Scotchbrite.
Now hold the Scotchie around the fork lower with a firm grip and rotate, repeat repeat repeat up the lower until it's done. Go round only, not up and down.
This should give a very even, dull~satin brushed finish. Soaking the scotchie in WD40 gives a lightly brighter finish. If that's still not enough there are several grades available for the finish you need.
Wash it all again in hot soapy water.
If you want you could clearcoat it to preserve the finish, or just give it a quick rub-a-dub next time it needs it.
Oh, and finger prints show up very well on the scotchbrite finish so don't be grabbing at them with dirty digits!
It was much quicker to write this than do the job. Don't be impatient, you'll get there in the end.
Fri Apr 23, 2010 11:25 am » Post: #7 » Download Post
Because I'm lazy, I sent mine off the Fitforx to fit new uppers, polish and laquer the lowers Smile
