Oil leak from dry clutch
Mon Apr 12, 2010 8:54 am » Post: #1 » Download Post
Which strikes me as a bad thing...
Seems I have evidence of an oil leak showing on the clutch cover grills and frame. Bugger.
Is this gonna be a crank case split job?
And is it most likely to be one of these two seals?:
26 91204-KV3-841 Oil seal 69x84x8 (ally)
27 91207-KV3-781 Oil seal 28x40x8 (ally)
(as shown on the clutch parts page for an SP)
Whilst I'm looking, it seems there is an error on the page, as item 24 looks like a seal yet is described as the ball bearing, and item 28 is listed as a seal. Is it just me?
Mon Apr 12, 2010 9:07 am » Post: #2 » Download Post
It'll be the seal behind the clutch basket. It only involves taking the right hand engine cover off, after removing the clutch basket of course.
Mon Apr 12, 2010 9:40 am » Post: #3 » Download Post
Ah cool not so drastic then. Don't suppose you can confirm which of those seals it is can you?
Mon Apr 12, 2010 9:42 am » Post: #4 » Download Post
The big one! Wink
91204-KV3-841
Mon Apr 12, 2010 9:47 am » Post: #5 » Download Post
The expensive one! Laughing
Cheers Andy. Hello Lings?
Manny Fagnet
Fri Apr 16, 2010 7:09 pm » Post: #6 » Download Post
This happend to me and I too changed the big oil seal only to find the problem returned.
It turned out to be an O ring on the shaft behind the crankcase cover. I did all the work with the motor still in the frame and only had to remove the cover behind the clutch to get to the 50p O ring. My incompetence cost me a new a new gasket as the kickstart assembly comes off too.
No problems since and I think this O ring failure is rare.
if it had a tail - it would wag
Fri Apr 16, 2010 11:50 pm » Post: #7 » Download Post
Thanks for the heads up. Think I'll order the lot and do them all, that way I'll be sure to have everything covered.
mixalisen
Sat Apr 17, 2010 6:36 am » Post: #8 » Download Post
Dave,
i think this will be the best... Small cost compare to big relief...Dave pay also attention to the washer that goes in the water pump shaft... Don't forget to place it back in its position...
Mon Apr 19, 2010 11:11 am » Post: #9 » Download Post
Hmmm, first hurdle, who's got a tool for holding the clutch so I can remove the nut?
Deon
1990 Honda NSR250 MC21
Mon Apr 19, 2010 4:33 pm » Post: #10 » Download Post
Dave,
A pneumatic impact wrench is the easiest way to take the nut off. I'm sure you could borrow one if you don't have your own. No need for fancy special tools for this one.
Deon
Mon Apr 19, 2010 4:54 pm » Post: #11 » Download Post
Funnily enough I've just been and bought this:
wrench
Mon Apr 19, 2010 5:23 pm » Post: #12 » Download Post
Though still need a clutch tool to torque it back up again Wink
Mon Apr 19, 2010 6:04 pm » Post: #13 » Download Post
Well this is the leaking seal:
And I prised it out:
So I'm guessing I don't need to remove the side cover from the motor?
Mon Apr 19, 2010 7:30 pm » Post: #14 » Download Post
If you've managed to prise the seal out then there is no reason to remove the engine cover.
Mon Apr 19, 2010 7:46 pm » Post: #15 » Download Post
Phew! Thanks for confirming that.
As for torque, I'll just use the same tool to clatter it back on till the thing lines up where it came from! Wink
