Honda GN2 oil okay?
Twilight
    Send private message View user's profile AIM Address
Honda GN2 oil okay?
Fri Mar 19, 2010 8:31 pm » Post: #1 » Download Post
The side of my nsr has 2 different oils listed. But neither are sold where I live... is the GN2 oil okay to use? Its a Injector/Premix oil
Sat Mar 20, 2010 9:28 am » Post: #2 » Download Post
Are there any motocross shops near you? Or who do mail order delivery?
Never heard of GN2 oil...
Sun Mar 21, 2010 5:32 am » Post: #3 » Download Post
You could do a lot worse in the US than have Redline ship you some decent oil! I think they stock Castrol TTS and Motul fully synthetics. I doubt you're going to go through it that fast, but even if you do, it's nothing to them to ship you a gallon of the stuff.
Always use good, fully synthetic oil with a proven record. People recommend stuff for a reason! I doubt very much there's anything "wrong" with GN2, but it's not a name that readily rolls off the tongue for an NSR in any country I know of!
Remember, that sticker on the NSR is probably getting on for 20 years old... oils have moved on a long way since then!
Masinari
GN2 Oil Revealed
Tue Mar 23, 2010 6:07 am » Post: #4 » Download Post
GN2 is the original Honda's own 2T performance oil sold for the NSR in Japan. i bought it in Japan and took some to the USA, i think it is actually semi-synthetic, but in stock trim the NSR is not that stressed, since the engine is restricted.
I actually have been running my MC28SP on GN2 and is running well, never fouling plugs, etc.
I heard that Castrol TTS is not that good, and some people complained about it. Is that right?
M A T T A S I N A R I
MATT ASINARI
MC28 R3T REPSOL
Location New York City/Connecticut
mixalisen
Tue Mar 23, 2010 7:31 am » Post: #5 » Download Post
Hi Matt,
Welcome to the forum... My opinion is that you will hear bad feedback for every oil or for everything in this world... But the main thing is that what the most people saying about something... I have used in the past the TTS or Motul 710 and both were great... The people probably who said that the TTS isn't good could have other problems in their bikes but they thought that it was because of the oil... Who knows...???
I hope you understand what I mean because my English are #%^&$...!!!!
Regards
Michael
bandit_7
Tue Mar 23, 2010 8:25 am » Post: #6 » Download Post
Well said Michael. Couldn't agree more.
Bandit 7
Tue Mar 23, 2010 12:05 pm » Post: #7 » Download Post
I have used TTS in my NSR for the last ten years, including a couple of seasons racing it and suffered no problems.
Masinari
Fri Mar 26, 2010 9:14 am » Post: #8 » Download Post
Thanks Michael for the welcome message/thanks guys.
I am very happy to hear this because I like Castrol as a brand and I saw thru the forum that I can get some TTS from Redline in the USA. Also less expensive than Motul.
I guess I have to drain the oil tank to do that. What is the best procedure?. I am wondering if I can suck it out from the top with a suction pump, unless there is an easy way from the bottom fitting of the oil tank.
Welcome your thoughts.
Very Happy:
MATT ASINARI
MC28 R3T REPSOL
bushman
Fri Mar 26, 2010 9:53 am » Post: #9 » Download Post
you could pull the pipework off the pump to drain the oil tank.
Fri Mar 26, 2010 10:13 am » Post: #10 » Download Post
You can top up with TTS if you've been using GN2. Semi-synthetics and fully synthetics mix no problem. You cannot however mix synthetics with castor based oils such as A747 or HTX.
As bushman says, if you're worried about diluting the TTS too much by just topping up, just pull the main feed off the pump and drain as much as you can, then top off with TTS. You'll be on 100% TTS then within 25 miles or so.
Chester362
Fri Mar 26, 2010 4:32 pm » Post: #11 » Download Post
I would just run it until the oil light comes on. Then top up the tank with the new oil. This will save the hassle and mess of draining the tank.
No need to waste perfectly good oil?
Is the oil in the tank very old, or of unknown age?
Of course, it`s entirely up to you.
Sat Mar 27, 2010 7:26 am » Post: #12 » Download Post
I didn't want to suggest that, just in case the sensor doesn't work, the bulb's blown, or there's simply no bulb in the holder!
Don't laugh... someone on here, who shall remain nameless, seized a motor because that light never came on because there was no bulb in the holder!!! Shocked
Chester362
Sun Mar 28, 2010 2:10 am » Post: #13 » Download Post
Very Happy
Well pointed out Andy. I should`ve thought of mentioning that too.
Can`t remember, but I think there is a check of the oil light when you turn on the ignition when in neutral? Or is it when you hit the kill switch when in neutral with the engine off? Confused
Sun Mar 28, 2010 12:04 pm » Post: #14 » Download Post
Yes, it's a combined ignition/oil warning light, but I don't think he knew that back then, or maybe just didn't notice! Laughing
He did say though, "the bloody oil light never came on!", so we checked it and found there was no bulb! Rolling Eyes
