Oil Pump Leak
anonymous.shyster
Oil Pump Leak
Thu Feb 18, 2010 2:42 am » Post: #1 » Download Post
I found out why my oil is going down so fast - it's leaking in to the gearbox. A common fault I've heard, netherless I'm a bit unsure on how to fix it.
I've taken off the oil injector pump and located a "seal" which I think is the one responsible for the oil leak, as well as two other O-rings. I'd decided to replace them all except the problem is locating the "seal". This seal has a 9.5mm inside diameter and no bearing shops or Honda dealer is able to find me a part number (even tried using this site) or a replacement that's even of an approximate size. Does anybody have any idea of where to locate a new seal? I'm in Australia.
80XAR
Thu Feb 18, 2010 4:18 am » Post: #2 » Download Post
Hey mate
Generally, the seal is reused with a little bit of sealant.
The genuine part number will be in the parts manual.
anonymous.shyster
Thu Feb 18, 2010 7:06 am » Post: #3 » Download Post
What sort of sealant is appropriate? I couldn't order the part from honda, despite finding a part number, not sure if it was the correct part number either, as they couldn't find it on their computer.
Thu Feb 18, 2010 10:02 am » Post: #4 » Download Post
The search function is your friend:
"oil pump seal"
80XAR
Fri Feb 19, 2010 11:28 pm » Post: #5 » Download Post
Hey mate.
You wont find a Honda dealer in aust that will be able to help you with it.
Try online. Tyga might have them.
