1993 NSR250R MC21, hard starting?
Twilight
    Send private message View user's profile AIM Address
Wed Dec 09, 2009 8:54 pm » Post: #1 » Download Post
Okay Ive had it since last September but I am now sick of the kickstart. It usually takes anywhere from 10-20 kicks to start the thing! Compression is around 180psi in each cylinder, plugs show good color with a tan tip and slightly darker around the edges;
All stock machine, no wire splices or modifications. New gas and Honda HP2 oil in the 2 stroke oil tank... what could be causing this? Spark is strong with a blue and white color emitting from the plug.
Wed Dec 09, 2009 11:00 pm » Post: #2 » Download Post
How many miles?
cgallant
2001 Honda RS250
Wed Dec 09, 2009 11:44 pm » Post: #3 » Download Post
compression seems to be good. Is that 180 on both cylinders?
Have you pulled the carbs apart and made sure the engine is getting enough fuel?
You can pull the plugs, put a small amount of pre-mix into each cylinder, replace the plugs and try to start it again.
if it starts easier, it's the carbs. if it doesn't then check the ignition system.
Twilight
Wed Dec 09, 2009 11:53 pm » Post: #4 » Download Post
Yes, 180psi in top cylinder and 183psi in the bottom cylinder. Tried pre-mix in the summer when I was doing my intial tear down and clean, it did start easier that way, but was only that way.
The bike has about 5800 miles on it, or 9400 kilometers.
Ive worked on and owned 2 strokes my whole life, but due to almost all parts for the NSR being on the other side of the world from the USA, I didnt want to start going into the internals without a good cause.
Hermit
Thu Dec 10, 2009 5:16 am » Post: #5 » Download Post
wouldn't difficult starting indicate an air leak? Perished crank seals perhaps? If its only done 5800 miles over its whole lifetime it may have been sat in storage for a long time which would've upset the crank seals. Including the centre one.
If the other suggestions don't yeild results you should put together a leak down testing kit to check for air leaks.
If you do a forum search you'll be able to find photos and details of the kit i made up for testing my engine.
Twilight
Thu Dec 10, 2009 5:33 am » Post: #6 » Download Post
Held 7psi in both cylinders for 4 hours... It has sat in storage but was always ran every 3-5 months from what I was told.
Leakdown test was done before I bought the machine... Too many 2 strokes in my life to know what not to buy.
Thanks all! I'll be starting on everything when it warms up... 20-30s too cold for riding.
My NSR will be on display at the Seattle bike show.
Kubira
Thu Dec 10, 2009 11:16 am » Post: #7 » Download Post
Just on spark plugs, ive found the plugs for nsr's to be a lil dicky. What i mean is, im used to, and its sort of common knowledge that a spark plug should be finger tightened, then just nipped up a lil bit.
However it seems that with these suckers, they need to be tightened up nice, and lets just say, a lil bit more than "nipped up" to get a good, solid seal
bushman
Thu Dec 10, 2009 12:04 pm » Post: #8 » Download Post
Battery condition?
cgallant
2001 Honda RS250
Thu Dec 10, 2009 2:36 pm » Post: #9 » Download Post
Kubira wrote:Just on spark plugs, ive found the plugs for nsr's to be a lil dicky. What i mean is, im used to, and its sort of common knowledge that a spark plug should be finger tightened, then just nipped up a lil bit.
standard installation procedure for plugs with proper torque has always worked for me on my NSR's.
The battery is always a good place to check as well, and is part of the ignition system trouble shooting process. These bikes require a good condition, full charged battery to start properly.
Charles Gallant
Canuck13
Thu Dec 10, 2009 11:08 pm » Post: #10 » Download Post
As Charles said. I find that if mine doesn't start within 5-6 kicks, its time to pull the battery and give it a charge. It then usually starts with the 5-6 kicks. Usually only happens when the bike has been sitting for a bit.
Twilight
Fri Dec 11, 2009 2:13 am » Post: #11 » Download Post
Whoa!? It has a battery! Jeeze talk about being a bloomin stick, I didnt even realize that!.
I need a manual for this bike.
Canuck13
Fri Dec 11, 2009 3:03 am » Post: #12 » Download Post
pmsl, talk to Charles, he has a great one for the MC28, but a lot of it can be dragged across to the 21.
wormser77
Fri Dec 11, 2009 7:03 pm » Post: #13 » Download Post
Nice to see another nsr in washington Cool
What part are you from? I'm over spokane in the land of the freezing lol
ring ding ding
Turn 1
Fri Dec 11, 2009 8:03 pm » Post: #14 » Download Post
I know mine takes more than a few kicks to start when it has not been run in a while. Makes sense to me the fuel in the bowls has lost its mojo and as you kick and kick and kick you eventually get enough fresh gas to start it.
Peter
Fri Dec 11, 2009 10:41 pm » Post: #15 » Download Post
Mine takes a hundred, or a push start. Ask martin Fitzgibbons. Embarassed
