  • NSR250 Forums Index ‹ NSR300R Discussion
Neal's 300
Page 1 of 4  Goto page 1, 2, 3, 4  Next Download Topic
Neal
Neal's 300
Fri Nov 20, 2009 7:13 pm » Post: #1 » Download Post
I put my bike on the dyno and i am very happy Very Happy
Dyno graph to follow tomorrow .
Hermit
Fri Nov 20, 2009 10:14 pm » Post: #2 » Download Post
sweeet, i for one am very much looking forward to seeing it!
Deon
1990 Honda NSR250 MC21
Neal's NSR300 Dyno
Sat Nov 21, 2009 11:34 am » Post: #3 » Download Post
http://i561.photobucket.com/albums/ss56/deon42_bucket/NSR250vsNSR300.jpg
http://i561.photobucket.com/albums/ss56/deon42_bucket/NSR300STDFlywheelvsSkimmed.jpg
And now the battle begins....................
Hermit
Sat Nov 21, 2009 11:55 am » Post: #4 » Download Post
HOLY S**T, 76 horsepower?! How did you achieve this figure?
Neal
Sat Nov 21, 2009 2:50 pm » Post: #5 » Download Post
Update ;
Dr Neels van Niekerk built my 250 race motor (69 hp) , he did the heads , squish and porting for pump fuel as per our rules .
He then built my 300 motor to his own specs for porting ect and we got 73 hp . I flipped the switch on my pgm and got 74 hp .
I then added the skimmed flywheel and got 75 hp .
Same dyno , same fuel , same tuner .
I know the guys will say that the dyno is happy . I am happy because the front wheel comes up alot easier than before Very Happy
Deon
TRUE Rear Wheel Ponies
Sat Nov 21, 2009 3:54 pm » Post: #6 » Download Post
I think we should focus on the improved HP ratings after the modifications rather than the actual figures given. The dyno that we (Neal, myself and some others) use in Durban is our benchmark and although it is believed to be reliable, I don't think it is reflecting TRUE REAR WHEEL HORSEPOWER. I found an interesting read here http://www.factorypro.com/dyno/true1.html and find it very difficult to believe that a modified NSR300 or a modified MC21 with NF5 barrels (my bike) could possibly make more "true rear wheel horsepower" than a kitted '98 HONDA RS250. In a previous post I saw that there was mention of an NSR with NF5 barrels (possibly Matt from Tyga's) that made 76HP in the good old US of A. This would be similar to the "not even close to stockish Yam TZ250 00-02".
So with all due respect to all the doctors and gurus out there, I think that horsepower figures should be looked at as an approximate value, not a "mine's bigger than yours" value. At least until everyone in the world uses the same dyno, and that's not going to happen!
Sat Nov 21, 2009 8:28 pm » Post: #7 » Download Post
Never a truer word spoken Deon.
Sat Nov 21, 2009 9:10 pm » Post: #8 » Download Post
It's the gain you're after, nothing else.
In the UK most people use DynoJet dyno's and tend to use the DynoJet calculated HP at the flywheel figure.
This is something like 60bhp for a good, stock, fresh, deresticted NSR 250. Anything up to 66bhp or so for a carefully tweaked one. Steve's F3 monster makes 74bhp. For comparision a stock 1991 RS250 makes 72bhp and 1996 one makes 76bhp.
Some others use DynoPro's, which can either give a true rear wheel HP figure or a DynoJet calculated figure.
Very few other dynos are in use over here.
Hermit
Sat Nov 21, 2009 10:07 pm » Post: #9 » Download Post
Very cool - do you know what power the 300 motor was making before the custom porting?
Neal wrote:I flipped the switch on my pgm and got 74 hp .
what does this mean?
Neal
Sun Nov 22, 2009 7:20 am » Post: #10 » Download Post
Hi Hermit ,
I do not have a before reading as the barrels needed to be machined .
I bought my barrels from a local breaker .
I am running a PGM II , the local race guys here open the box and join 2 things together and install a switch . All i know is that it made the graph smoother and more hp . He said it alters the powervale opning . I assume it alters the timing too . I will check my plugs at the track next weekend .
I can take a photo if you would like .
Hermit
Sun Nov 22, 2009 8:30 am » Post: #11 » Download Post
ah i see, no photo required thanks i just wasn't aware of the PGM II modification.
I look forward to reading about how it performs on track! - i've never dynoed my 300 (which is just a 'stock' Tyga kit), my only guage of its performance has been how it compares to other bikes down the straights at trackdays.
wb
Fri Nov 27, 2009 8:58 pm » Post: #12 » Download Post
A fella from SA on the TZR forum gets 95 ponies form his 3XV on that very same dyno...
http://tzr250.com/forums/index.php?action=dlattach;topic=589.0;attach=175
And that's only a 250! Shocked Laughing
Deon
Sat Nov 28, 2009 5:39 am » Post: #13 » Download Post
The ambient correction was not set on the dyno on that run. It must have been tested by the receptionist. Wink
wb
Sat Nov 28, 2009 10:52 am » Post: #14 » Download Post
Yes, that's kind of my point. Those numbers in isolation are pretty meaningless. Not saying that the tool isn't useful; just reinforcing your point that the only really informative use for dyno's is to measure changes on the same bike on the same rig or between different motors on the same rig - running the same settings etc.
That said, I have quite a lot of raw data for different bikes and same-model bikes running on different dynojet and dyna-pro rigs, and there seems to be pretty good consistency between the same kind of rig in different locations if you feed the raw data into the viewer with a set correction factor etc.
I've never encountered one of the Dyno Power rigs though. Are they manufactured in SA? Both look like reasonable power curves of course, which is the most important thing Very Happy .
Deon
Sat Nov 28, 2009 11:42 am » Post: #15 » Download Post
Hyper Power International rigs are made in SA and I believe they are popular in Australia too.
Did you see the spec on the TZR in question? Its a modified 3XV9 SPR RC Sugo kit (ex Kenny Roberts Track School). Very rare and sought after. I don't agree with the figure on the graph, but I do know that this particular bike is something special and that is all I have to say about that evil Yamathing!
