T1 28 Barrels.
rdstars
T1 28 Barrels.
Sat Oct 03, 2009 6:30 pm » Post: #1 » Download Post
It will probably get missed as most people just glance through posts so thought I would start a new post. I have done a search but nothing has come up.
Got my hands on an mc16, the barrels on there are marked T1 28 at the bottom on a round marking. Concidering the age of the bike I was wondering if someone previous has done a barrel swap? Have I got mc28 barrels?
Sat Oct 03, 2009 7:31 pm » Post: #2 » Download Post
Are they round (MC21/MC28) or hexagonal (MC16/MC18) in shape?
Do the heads each have a take-off on top of the main coolant hose union, with a small-bore (about 5mm ID) hose attached? This would almost certainly signify MC16, although MC18 heads bolt straight on to '18 cylinders.
I very much doubt someone will have fitted MC28 barrels and heads to an MC16.
rdstars
Sat Oct 03, 2009 7:42 pm » Post: #3 » Download Post
I thought they looked round, I will have another look tomorow and take a quick pic. I just got a little exited when I saw 28 on them.
Suppose it wouldent make that much difference as I could port them myself but would save a little work, not sure what the port map is like on the 16 but I did see the 21 port map in the tuning section.
Think im going to keep the 16 and do a rolling rebuild, will have to be like that as im a little un'employed at the moment Sad
NSR-lizard
Sun Oct 04, 2009 1:09 am » Post: #4 » Download Post
MC16 exhaust ports are tiny, so there`s huge scope for improvement. See if you can buy up an old knackered MC18 barrel and copy the porting. Wink
Vampire?
rdstars
Mon Oct 05, 2009 6:44 pm » Post: #5 » Download Post
Just thought I would update, the barrels do look hexaganel. Quick pic just incase anyone can tell me what ones I have.
2Smoke
1987 Honda NSR250 MC16
Mon Oct 05, 2009 8:16 pm » Post: #6 » Download Post
Look like standard ones to me mate! Cool
rdstars
Mon Oct 05, 2009 8:25 pm » Post: #7 » Download Post
Chears fella, I gess I got alot of porting to do Smile
Lets see how much I can get out of a standard modded motor.
Just another quick one, since knowone wants the standard mc16 barrels how much do they go for?
2Smoke
Mon Oct 05, 2009 8:27 pm » Post: #8 » Download Post
Never bothered selling any myself so dunno! '18 ones go for £150 ish with pistons and ready to go Cool
rdstars
Mon Oct 05, 2009 8:29 pm » Post: #9 » Download Post
I would gess then for a set mc16 of pistons and barrels that knowone wants about £40 tops....
Just a thought on having a spare set to port, build my own pipes, 28mm carbs should be good for around mid 65hp.
