spark plug cable
Jim996
spark plug cable
Wed Sep 16, 2009 2:15 pm » Post: #1 » Download Post
Hi all,
My MC21 has a torn plug cap and I just got an NGK plug cap&cable. Can anyone tell me if this cable can replace the original one?
Can original cable be removed from the coil and I can just fit the new cable directly to the coil?
Thanks,
Jim
[/img]
nxrsr20
Wed Sep 16, 2009 8:02 pm » Post: #2 » Download Post
unplug the spark plug cap from spark plug, unscrew cap from cable, fit new one by doing the reverse procedure Smile
Jim996
Thu Sep 17, 2009 5:52 am » Post: #3 » Download Post
Thanks nxrsr20,
the cap i have comes with cable. Can the cable be changed as well? Would like to post the pic, but don't know how to do Embarassed
nxrsr20
Thu Sep 17, 2009 7:57 pm » Post: #4 » Download Post
I've only changed caps before, but changing lead and cap at the same time most certainlycan be done. There are two spade connectors (female on the leads I believe) that you unplug, unplug the spark plug end, and then get the cable out. Thread the new cable back in and plug it in and see if it will fire up Smile
Just pay attention to the routing of the original cable, and try not to subject the cable to sharp bends or kinks.
dunkenb
1989 Honda NSR250 MC18
Thu Sep 17, 2009 8:04 pm » Post: #5 » Download Post
if you cut out around where the cable goes into the coil you'll find that the coil has a screw on connector the same as the plug cap end. just screw the new HT lead into the coil and fill round the end with black silicon sealer .
good as new!!
Jim996
Fri Sep 18, 2009 12:53 am » Post: #6 » Download Post
Thanks everyone! That helps a lot! I will try this weekend.
cheers.
