does my clutch need replacing?
ashleymills
Mon Aug 17, 2009 6:37 pm » Post: #1 » Download Post
Clutch appears to be slipping a lot, and I have squibbled the jibbly on the cluch lever all the way in as far as it can go (whereas doing so previously would have actually engaged the clutch, now it can be done).
So the adjustment is to the hilt yet it still slips. I am assuming this means my dry clutch needs replacing?
Do I have to replace the whole thing or I guess I can buy just the plates or something?
Ashley
Mon Aug 17, 2009 6:40 pm » Post: #2 » Download Post
You can just buy the plates and something Wink
Genuine Honda are best or a complete upgrade kit from NSR-WORLD.
ashleymills
Tue Aug 18, 2009 11:55 am » Post: #3 » Download Post
OK thanks. I'll have to take a look in the marketplace section when it goes out of maintainence.
Is replacing the clutch plates something which can be done oneself or does it require specialized tools?
Ashley
Tue Aug 18, 2009 12:34 pm » Post: #4 » Download Post
If it's an SP then it's a piece of pudding. Could probably be done in under 10 minutes if you had to.
R spec is a different kettle of bananas. Will take longer as you'll need to drain the oil (and water), or tip the bike over on it's side if you're a tight arse Wink as the cover needs to come off, so will probably require a new gasket as well.
On the SP, once you've got the fairing out the way all you need is 10mm T bar, and a torque wrench with a 10mm socket. Oh and maybe a couple of pokeys to pick the plates out.
R is pretty much the same in the way of tools. Nothing special required.
cgallant
2001 Honda RS250
Tue Aug 18, 2009 12:58 pm » Post: #5 » Download Post
Of course if you have the adjuster backed out all the way, you may want to change out the clutch cable as well when you do the plates. Could have a worn/stretched clutch cable along with worn clutch plates.
Contact Andy directly, as the store probably won't be up anytime soon, or contact one of the supporting vendors for quicker ordering.
Charles Gallant
ashleymills
Tue Aug 18, 2009 6:33 pm » Post: #6 » Download Post
ok thanks, i'll get on it
sgthui
Tue Aug 18, 2009 10:46 pm » Post: #7 » Download Post
"squibbled the jibbly"
"piece of pudding"
"kettle of bananas"
What language is it that you guys are speaking?
cgallant
2001 Honda RS250
Tue Aug 18, 2009 11:40 pm » Post: #8 » Download Post
They are speaking the queens english, not proper american english.
Charles Gallant
Wed Aug 19, 2009 2:26 am » Post: #9 » Download Post
Queen and English have capital letters, I'll have you know.... "american" doesn't matter though! Laughing
sgthui
Wed Aug 19, 2009 2:40 am » Post: #10 » Download Post
I have been to Queens and while you could probably get your jibblys squibbled for a 20 rock I sure don't remember them talking that way. And if you wanted to involve pudding and bananas it would certainly cost you an additional fat 20.
Wed Aug 19, 2009 3:51 am » Post: #11 » Download Post
Where I live you can get your jibblys squibbled in a banana pudding for far less than a score.
And it doesn't matter if you can speak the Queen's English or not.
If you're holding folding, you're sorted.
ashleymills
Tue Aug 25, 2009 12:00 pm » Post: #12 » Download Post
I tried sending Andy a PM but I got no response. Are you around? Got any clutch plates?
So I have an SP engine.
Do all the SP engines use the same clutch plates?
Do I need just the clutch plates? Or do I need the cable as well? Are there any other clutch related parts that might need replacing?
I don't know who the supporting vendor's are, if you are reading this supporting vendors, do you have the parts I need?
Ashley
nxrsr20
Tue Aug 25, 2009 7:57 pm » Post: #13 » Download Post
the supporting vendors are in the banner at the top of the page....so the likes of redline, TYGA, and jap4performance
If you're changing the clutch plates, are you replace both the corks and steels? You should measure your clutch springs to see if they need replacing at the same time. Yes you should check your clutch cable to see if it is frayed or worn so you know whether or not that needs replacement too.
ashleymills
Wed Aug 26, 2009 11:50 am » Post: #14 » Download Post
OK thanks. So basically I need to remove the clutch assembly and do the following four things:
1) Measure the springs
2) Look at the cork plates
3) Look at the metal plates
4) Look at the clutch cable
This leads me to ask the following three questions:
1) Where can I find information about how long the springs should be?
2) What am I looking for with regard to the cork plates?
3) What am I looking for with regard to the metal plates?
Thanks
Ashley
ashleymills
Wed Aug 26, 2009 9:03 pm » Post: #15 » Download Post
ok i hear the silent cries of RTFM
I just realized there is a workshop section with a handy set of instructions with regard to the clutch installation
