Radial Master Size
fstnsr
Radial Master Size
Fri Aug 21, 2009 5:12 am » Post: #1 » Download Post
What size radial master cylinder does one need to use with standard mc28 calipers?
94 mc28 SE
mixalisen
Fri Aug 21, 2009 5:55 am » Post: #2 » Download Post
Anything between 16 to 19 will do just fine...
fstnsr
Fri Aug 21, 2009 6:03 am » Post: #3 » Download Post
What does the different sizes do? Is it the best size to get?
94 mc28 SE
mixalisen
Fri Aug 21, 2009 6:18 am » Post: #4 » Download Post
Different sizes give different feel... But it's not only the bore on the radial pump that matters, but also the stroke...
For example, the bigger the stroke is, then you get more progressivity in your braking...For road use, the best combination is 19x20 (borexstroke)... If you want the pump for racing you can go 19x18 or even 19x16(extreme)...
nxrsr20
Fri Aug 21, 2009 9:46 am » Post: #5 » Download Post
If you'r lazy to guess sizes, just get one off a known twin rotor setup like a CBR/GSXR/R6
apexxn
Fri Aug 21, 2009 5:09 pm » Post: #6 » Download Post
I have a Brembo 19x18 on my 28 and it's perfect.
A 19x18 will give you more feel and the 19x20 will give you more power.
