Trip to Scotland takes its toll - exhaust advice needed
Manny Fagnet
Mon Jun 29, 2009 8:05 pm » Post: #1 » Download Post
Please bear with my ramblings but you may need the information to give me help.
The welds on my chambers are failing at an alarming rate.
Its a 300 motor with TYGA side by side chambers and mufflers.
They were held at the head with springs onto the angled collar thingy and secured at the central mounting point above the expansion chamber.
The left exhaust snapped off last year immediately after the expansion where the narrow pipe joins. There is actually a supporting plate here too, still fell off though.
I blamed the fact that the spring attachment (not being rigid) allowed enough movement for the pipe to 'wag' after the anchor point and eventually, due to the weight of the muffler weaken and snap this weld.
So I got the angled collars welded to the header pipes and I then had a lovely rigid system and also ended the annoying oil issues I had here.
This worked for a year untill my recent trip.
Now the right side has 3 failed welds (central mounting plate, after expansion chamber- same as left side, and at the header pipe where it simply ripped itself off the mounting collar)
Here are my questions
*Is the system under too much stress now that its rigidly mounted?
*Is the standard 250 motor and chambers held together with springs or rigidly mounted?
*Do I need to manufacture mounting brackets from the mufflers to my GP rear sub-frame to support them?
*Are there any more substantially constructed systems out there to fit the 300 motor that still gives me full power?
Has anyone ever made their own using the TYGA system as a model?
*Has anyone else suffered these problems?
This is no way a pop at TYGA chambers because I'm sure I ask too much from them and maybe they belong on a circuit, but I built the bike to ride (not to put it on a coffee table) so need to fix it with improvements.
I'm fed up with the only advice I get from my friends -Why dont you buy a real bike (poor souls) so I turn to you good people.
if it had a tail - it would wag
Mon Jun 29, 2009 8:57 pm » Post: #2 » Download Post
Mine used to crack the welds. I had them welded up a number of times.
Cured it by fitting stays to the cans from the sub frame. Not had a problem since.
Manny Fagnet
Tue Jun 30, 2009 1:47 pm » Post: #3 » Download Post
Thanks, trip to the welders and time to design some stays then.
Wed Jul 01, 2009 11:28 am » Post: #4 » Download Post
Have you got the standard can brackets the bike came with? Maybe they'd fit with a big P clip...
Manny Fagnet
Wed Jul 01, 2009 2:03 pm » Post: #5 » Download Post
No, I never actually bought a bike to develop it to what I have now. I simply knew what I wanted and went up from a rolling chassis.
I'll look through the parts list to see if there are stays I can start with and work from there, Thanks.
