MC18 top cylinder backfiring plus free bits
Damian Waters
Sun Jun 14, 2009 2:30 am » Post: #1 » Download Post
I have a MC18 that is backfiring from the top cylinder. The bike was running beautifully last track day, a couple of weeks ago. The other cylinder is running fine. But the top cylinder is not running then backfires every so often.
I figured it must obviously be either fuel, air or spark. So I changed out the carbie for a spare unit, same problem. I read the topics about the coils, so I put on a new coil, swapped coils, cleaned connectors etc, same problem. I checked to see there was a spark and it was sparking fine. I put in a new plug as well
I removed the exhaust to check no blockage. I checked the reeds and they are fine but swapped left to right anyway. Still same problem.
I checked and cant see anywhere that is allowing an air leak on the cylinder.
I love this bike as it is real ball tearer but I am not having much success diagnosing this problem. Any help would be greatly appreciated.
I have 2 x MC21's as well both going through ground up rebuilds. I have a lot of spare indicator lights, undertrays, oil containers, some fairings etc, all the stuff not required on track bikes. These are free to anyone who wants to pay for the postage. Better than going to the dump. I am based in North Queensland Australia so email me if there is something you are after.
Sun Jun 14, 2009 10:15 am » Post: #2 » Download Post
Can you describe the backfiring? Is it more of a misfire?
Damian Waters
backfiring
Sun Jun 14, 2009 12:08 pm » Post: #3 » Download Post
Hi,
The bottom cylinder runs fine. The top cylinder wont run then every 30 secs or so makes a big pop which you can feel out the exhaust. Then nothing until the next bang.
Sun Jun 14, 2009 12:13 pm » Post: #4 » Download Post
Ah, so actually it's barely running, then now and then it fires! Rather different to a mis fire...
How do the plugs look? black? brown? wet? dry? plain silver and sparkly as the day you fitted them?
Damian Waters
backfiring
Mon Jun 15, 2009 9:30 am » Post: #5 » Download Post
When it did fire it went with a bang not a normal firing. I got home from work today and decided to pull the cylinder off before dinner and I found that one of the piston rings was broken. The cylinder has a small score too. So now I have to get it all fixed before race day this weekend. Lucky I have a couple of spare engines to rob. Still after fixing helicopters all day I dont feel like spending my evenings getting greasy again. However its worth it when you manage to smoke all those 4 strokers on the track.
