Moto Gp Gear-shift
Kubira
Moto Gp Gear-shift
Sun May 17, 2009 3:39 pm » Post: #1 » Download Post
The 250 gp bikes up change by kicking down, and of course down change by up kicking. Can the NSR(mc21) be modified the same?.
I think the 800's do also, but I dont have one of those
cgallant
2001 Honda RS250
Sun May 17, 2009 3:46 pm » Post: #2 » Download Post
You can swap the gear shift knuckle to run what your looking for. Simple remove the knuckle from the gear shaft, turn it 180 degrees and put it back on.
Charles Gallant
hutch
Sun May 17, 2009 4:39 pm » Post: #3 » Download Post
I run race shift on all my bike and it has already been said its simply turning the knuckle 180 degrees. Be careful though when you first do it as its easy to change the wrong way and lock up the rear or worse. I ended up with a slipper clutch which helped when i got it wrong.
lam.666
Mon May 18, 2009 6:54 am » Post: #4 » Download Post
i noticed when i did this, i had a problem with it hitting something, can't remember what it was hitting but i think it was the stock expansion chambers
although my knuckle was pretty buggered
Mon May 18, 2009 6:56 am » Post: #5 » Download Post
Sometimes they hit the side stand on the MC21's. That might of been it.
Kubira
Mon May 18, 2009 11:08 am » Post: #6 » Download Post
yes, the side stand is well in the way for mine, and it would be well on the piss if it was able to connect
cgallant
2001 Honda RS250
Mon May 18, 2009 11:37 am » Post: #7 » Download Post
you can remove the side stand and it should clear no problem. Okay, may not be the best option for a street bike Smile
I know Tyga made a setup that allowed the knuckle to clear the side stand. Not sure if they still make it. Should be able to find it in their site if they do.
Other option is to grind away the side stand to allow clearance for the knuckle to move freely.
Charles Gallant
