brake light and gas tank
senza9
Guest
Wed Sep 22, 2004 8:12 pm » Post: #1 » Download Post
my stock brake light wont light up when the brake is hit ,, the bulb and fuse are good so i dont know what the problem could be ,, also i have a used gas tank i picked up with no key , any suggestions about getting it open ?
Guest
Wed Sep 22, 2004 11:15 pm » Post: #2 » Download Post
Take it to any (good) lock shop and they can make one. I have had it done many tiimes.
Thu Sep 23, 2004 9:12 am » Post: #3 » Download Post
Is that with both lever and pedal?
s9
Guest
brakes
Fri Sep 24, 2004 3:33 pm » Post: #4 » Download Post
yes both pedal and lever fail to activate the brake light , has anyone had this problem before ?
Mon Sep 27, 2004 7:22 am » Post: #5 » Download Post
Well that narrows it down. Have you checked that there is 12v at the bulb?
s10
Guest
brakes
Mon Oct 04, 2004 4:36 pm » Post: #6 » Download Post
well i have not checked that , but why wouldnt there be all 12 volts going there, i guess i will buy a multimeter tonight and do this test.
Seth
Mon Oct 04, 2004 6:35 pm » Post: #7 » Download Post
I don't know about the front brake leaver but the rear brake should have a spring that activates the switch to the brake light maybe it's missing?
/\/SR-150 SP Its Special
Kubira
Sat Apr 11, 2009 9:28 am » Post: #8 » Download Post
I have 2 light related probs,
- no rear brake light, front is fine
- front brake light only work when lights on, no day time riding at the moment
Sat Apr 11, 2009 11:00 am » Post: #9 » Download Post
Ride with your lights on then... even during the day! It's safer. Smile
Very rarely will you see a biker in the UK without his lights on in daylight. Well, except for me at the moment, as I don't have any lights! I'm sorting a way to retify that though, with a super-bright LED marker light to hide in the nose a little like a camera on the GP bikes.
Better to be seen than sorry.
Re: brakes
Sun Apr 12, 2009 8:35 pm » Post: #10 » Download Post
s10 wrote:well i have not checked that , but why wouldnt there be all 12 volts going there, i guess i will buy a multimeter tonight and do this test.
you need 12v one side and earth the other, so there's gotta be 12v at some point!
