Hey guys, had a bit of a search around. I was wondering where this hose goes to on my MC16.
Water comes out of it when the bike is running. Does that mean the thermostat is stuffed?
Blair
It goes to the bleed nipple on the rear cylinder head, on 16 heads that is, if youve got 18 heads im not sure if they have a nipple or not. If they havent I would cut the hose back and block it off.
Ah hah! I knew you guys would know!
So far so good, it's idling a little high, might need an air-screw adjustment and bit of a carb balance.
Cheers mark
