mc21 dead power valve...
mr_penguin
    Send private message View user's profile ICQ Number
Wed Mar 18, 2009 1:20 am » Post: #1 » Download Post
I guess the subject says it all..
To the point,,,
I'm picking I have a dead regulator and it's killed the pgm's power valve
circuit..
To me it looks like a fried transistor in the PGM. I don't know how to attach and image
to his posting....
wish i did....
If you look at the pgm with the white and black plugs facing away from you on the
left side below the black plug there are 4 transistors in a line.
the transistor on on the end of the this group of 4 seems to be heat damaged...
Are these parts used to drive the power valve servo ?
I have fixed PGM's before with dead capacitors but not a power valve
problem.....
I think I will be able to get the transistor part number off the part once
i dig it out of the potting mix...
Also any know the source of a new regulator ??..
Best regards
Ian
dunkenb
1989 Honda NSR250 MC18
Wed Mar 18, 2009 5:30 pm » Post: #2 » Download Post
think the bits on the left of the pgmIII are power valve gubbins.
sure someone will correct you if your wrong.
as far as i can tell its in the same position on the pgmII i have on my mc18
mr_penguin
Wed Mar 18, 2009 9:02 pm » Post: #3 » Download Post
To me it looks like a dead fet a 2sk1059. in the pgm
I have done some digging and it seems that honda have
discontinued the regulator that that MC21 came with the sh609-12
and replaced it with a part numbered 31600-MV4-010
Has anyone tried one of these 31600-MV4-010 regulator on
an NSR ?..
I also have a regulator off an mc18 some place if I can find it
wil that work on the mc21 ?
I can also try the mc21 servo on my mc18 if they are the same part.
regards
Ian
Wed Mar 18, 2009 9:42 pm » Post: #4 » Download Post
Any reg/rec will work if you wire it in properly.
mr_penguin
Wed Mar 18, 2009 11:02 pm » Post: #5 » Download Post
That sounds about right.
I'm going to wire in a 6 wire regulator as i'm told the 5 wire type that's on the
NSR is well know to kill pgm's.... i'm told the nc30's have the same problem....
I just tested the servo from my mc21 on my mc18 and it's fine...
So that leave my pgmiii....
ebay might help with a new regulator...
Regards
Ian
