Air Leak?
biketrix
Air Leak?
Fri Feb 20, 2009 10:11 pm » Post: #1 » Download Post
I have a quick question for the experts. I can start the bike, blip the throttle and it revs freely, on occasion the revs will hang up for a second or two, then fall back to idle. Does this sound like an air leak?
Thanks!!
Jim
Sat Feb 21, 2009 3:07 pm » Post: #2 » Download Post
Not an expert but.....could be an air leak but could be something simple like having your idle set a little too high - happened to me - once I adjusted it down to 1250 or so, no more rpm hang up. Maybe you'll get lucky too. Good luck.
-Jim
'93 MC21
Sat Feb 21, 2009 3:14 pm » Post: #3 » Download Post
It can also be caused by the carbs being alittle out of balance which is a very easy fix and quite simple to check.
DifferentStrokes
Sun Feb 22, 2009 12:26 am » Post: #4 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 10:27 pm; edited 1 time in total
biketrix
Sat Feb 28, 2009 5:53 pm » Post: #5 » Download Post
Thanks for all the advice. It was not an air leak. A good carb clean and adjustment and it's good to go!
