Blocking pin
sr71gator
Blocking pin
Sun Jan 11, 2009 11:45 pm » Post: #1 » Download Post
Slowly this comes together...
I've got the jet kit in, but there's one part I haven't figured out where it goes. 96205-04005 x2 is supplied, but it doesn't make any sense as to where to use it. I originally thought it was for blocking off the PJ, but no, my kit had 2 small solid PJ blanks that thread in.
Anyone?
Mon Jan 12, 2009 12:34 am » Post: #2 » Download Post
So, what do you have two of, that you don't need?
montsta56
Mon Jan 12, 2009 12:34 am » Post: #3 » Download Post
I Think the bits you mention are for blocking off the oil feed for the oil pump seen you'll be running pre-mix. I belive they go into hose between the two oil feed pipes.
Mon Jan 12, 2009 12:35 am » Post: #4 » Download Post
And first prize goes to montsta56! Smile
sr71gator
Mon Jan 12, 2009 4:05 am » Post: #5 » Download Post
Thanks! You have to understand some of this is confusing because I have more than just the HRC kit - I've got extra bits somehow; i.e. two 'y' pipes, 4 emulsion tubes, etc. So I've got these lovely rubber caps that fit over the oil feed tubes on the carbs, negating the need for the blocking pins.
Or I just peel out the brass tubes and put in the pins.
Mon Jan 12, 2009 7:41 pm » Post: #6 » Download Post
You can either glue the caps to the 2T feed unions or cut the feed pipes to about 20mm and glue in the alloy bungs. Either is acceptible.
