What clip ons?
andreb
What clip ons?
Thu Dec 04, 2008 10:42 pm » Post: #1 » Download Post
What handle bar/clip on set up do you guys run?
I have the stock set up and the angle is super-steep. Even worse than my Ducati, which I didn't think was possible.
I'd like a less steeper angle and something that is two piece at the fork leg end.
Cheers,
Andre E. Benguerel
1996 Honda NSR250R
2000 Honda RS250R (NX5)
2008 Honda RS250R (NXA)
AFM Expert #430
Thu Dec 04, 2008 10:56 pm » Post: #2 » Download Post
i got some harris clip ons for mine and their at a normal angle and they have the removable tubes.got them off ebay and they were off a zx10r
cgallant
2001 Honda RS250
Fri Dec 05, 2008 7:15 pm » Post: #3 » Download Post
Look into WoodCraft (http://www.woodcraft-cfm.com/Scripts/default.asp) for opotions.
I use stock and yes, they are steep. Sucks when your wrist is jacked up.
Charles Gallant
andreb
Fri Dec 05, 2008 8:25 pm » Post: #4 » Download Post
Ooh, I like the hinged Harris one!
Chaz - what are the fork tubes OD on your RS? Are the 2001 and newer forks larger in size when compared to the early bikes?
cgallant
2001 Honda RS250
Fri Dec 05, 2008 8:54 pm » Post: #5 » Download Post
The 2001 RS250 has 41mm forks.
I believe the previous model year had the same size forks.
Charles Gallant
Fri Dec 05, 2008 10:14 pm » Post: #6 » Download Post
I think he means the OD of the leg Charles, not the stanchion!
Can't remember if the NX5 is 50mm or 52mm. I'm using RVF400 clipons on mine, but on the lookout for some Harris ones like Si's from time-to-time when I remember! Smile
cgallant
2001 Honda RS250
Fri Dec 05, 2008 10:23 pm » Post: #7 » Download Post
Well I see the problem now. It's Friday and I'm simple reading every third word Smile
Okay, pre 01 I believe are 50mm while 01+ are 52mm
Charles Gallant
andreb
Fri Dec 05, 2008 10:25 pm » Post: #8 » Download Post
Andy wrote:I think he means the OD of the leg Charles, not the stanchion!
Thanks Charles, but Andy is right. The tube at the triple clamps. Battle Factory lists the 90-00 as 50 and the 01-on as 52.
So my planned fork upgrade won't just be a quick slip in job. Looks like I will need the triples, clip ons, etc...
Andre E. Benguerel
1996 Honda NSR250R
AFM Expert #430
Fri Dec 05, 2008 10:45 pm » Post: #9 » Download Post
Can't you get the current triples milled out to 52mm? You can then have a set of shims made up if you ever want to re-sleeve them to take the original forks again.
Saves having a custom stem made and worrying about the offet and lockstops etc. of the different triples.
andreb
Fri Dec 05, 2008 11:01 pm » Post: #10 » Download Post
I guess milling would be an option. My thoughts were the old front end would find its way into the NSR Wink
The offset is the same and so is the stem diameter (same bearings on both bikes) . I would imagine the stops are the same as the headstock areas are nearly identical. The stem length is another question?
Chaz - whats the stem length on your RS?
Andre E. Benguerel
1996 Honda NSR250R
AFM Expert #430
