MC18 Rear Sub frame
hutch
MC18 Rear Sub frame
Mon Nov 17, 2008 9:01 am » Post: #1 » Download Post
First of all hi guys , i have been reading this forum for a while but thiught it was time to join. I 've just bought an MC18 of a friend who has had it in his shed for a few years after putting it in a ditch. Its a little sorry for itself with no bodywork and a slightly bent fork, however the biggest issue was the lack of subframe which was badly twisted so he threw it away.
The plan is to trackday the bike maybe with a daylight MOT. Tyga bodywork, although they only appear to do road fairings but i can always get busy with the fibreglass kit. Biggest problem is that they don't do a sub frame kit for it like they do for 21/28. Does anyone know if i can use the MC21 tyga subframe kit with minimal alteration or perhaps i am going to have to get a bespoke one made?
Kieran
Mon Nov 17, 2008 10:19 am » Post: #2 » Download Post
MC18 and MC21 subframes are very different.
The MC18 has all four mounts on the frame, MC21 has upper pair of mounts of the upper shock mount, lower pair off the frame.
Put a WTB in the classifieds. Someones gotta have one...
The Chopster
hutch
Mon Nov 17, 2008 11:48 am » Post: #3 » Download Post
Kieran thanks for the reply and the advice. I have just popped onto the sales and wants and posted up. Fingers crossed that something comes up or it might be Tig time.
dunkenb
1989 Honda NSR250 MC18
Mon Nov 17, 2008 9:49 pm » Post: #4 » Download Post
was thinking of getting the same seat unit for my 18, my only worry ( aside from the sub frame issue) is that the 21 frame spars are slightly wider appart ,so would the part of the seat that sits on the frame spars be too wide for the 18. maybe its flexible enough to be pulled in alittle???
dunk
Tue Nov 18, 2008 9:26 am » Post: #5 » Download Post
Know anyone that could fabricte one? They're not really a complicated piece of equipment.
dunkenb
Tue Nov 18, 2008 10:30 am » Post: #6 » Download Post
emailed matt at tyga, and with some modifying to the mc18 with a hacksaw and a welder it could be made to fit. or you could modify the tyga subframe to fit the 18 frame.
dunkenb
Wed Nov 19, 2008 9:09 am » Post: #7 » Download Post
looking at the tyga sub frame the lower mounts onto the frame look to be pretty similar. and on the top ones that mount above the shock,you could quite easily extend the box section to reach the original mounts on the 18 frame, just use small box section and insert it into the tyga sub frame and adust it to length and angle of the seat unit. the either bolt it all up or weld it. jobs a good un.
plus by using the tyga kit you get the mounts for the reg/rec ,battery and pgm unit.[/img]
