zxr forks
dunkenb
1989 Honda NSR250 MC18
zxr forks
Thu Nov 06, 2008 8:47 pm » Post: #1 » Download Post
just got some zxr400 forks to put on my 18. question is... is it easy to get the fork bottoms off as i want to powder coat them or am i better off just masking off the stantions???
cheers guys.
dunk.
Thu Nov 06, 2008 9:56 pm » Post: #2 » Download Post
Can't say for sure with ZXR forks (try either the 400 forum of some ZXR specific one) but NSR forks come to bits very easily.
I'd have thought the powder coat guys would want them took apart anyway Question
Moriwaki-man
Get them off
Thu Nov 06, 2008 11:36 pm » Post: #3 » Download Post
If you haven't got access to an airline with ratchet get yourself down to a local garage that has one - saves rounding off any seized bolt , then you'd be in a world of pain ! Don't recommend you leave them on for powder coating and masking off - inevitably they'll get blasted or coated !!
Apart from that they will strip apart easily.
Is it L or H model you have? Or were you lucky and got an SP set Cool
Have seen this done to several NSR's here , some with 250 some with 400 USD's.
You'll need your 400's re-sprung as the dry weight of the bikes is different but the 250 is similar otherwise you wont be able to set the sag on them right. Worth wile as they will make your front end feel so "planted" Keep in mind your original ride height when setting them up hopefully your looking at only dropping them through the top bridge a few mm to get the same trail as the originals.
Recommend Yamaha fork oil for when your re-building.
Best of luck and want to see pic's of your build
Smile
Resistance is futile!
dunkenb
Fri Nov 07, 2008 2:52 pm » Post: #4 » Download Post
not sure of the model, the seller said the bike was 1990. how do i tell the difference?
will post some pics when i get them on. just got few more bits to turn up( oil seals, bars and a mudguard) then gonna pull em apart and get the yokes and bottoms off to the powder coaters for a coat of satin black.
Moriwaki-man
H model
Fri Nov 07, 2008 3:42 pm » Post: #5 » Download Post
1990 should be H2 forks.
Tops will be 50mm (same as L model) and bottom will be 52mm (L is 54mm)
I'll hunt the triple lip seals I have in the cupboard and tell you who makes them (got them from blighty).
all internals are still available and worth replacing - overhauled mine about 14 months ago and are still solid Very Happy
Just under the calliper mounting brackets if you have an adjuster they are SP model (most sought after). Callipers are 62mm spacing so MC28/21 fit straight on Cool
You can also get Tokico 6 pots that bolt on too (got on mine) and there are a few other options too....
The wheel pattern will be well off your NSR wheels so recommend you make spacers up to fit your OEM one back on, if I remember rightly the spindle is 17mm.
Do have them re-sprung though, your going to get a lot of "chatter" otherwise and high speed tank slappers Shocked , once that's sorted your going to notice how soft your rear shock is Laughing
MM!
dunkenb
Sat Nov 08, 2008 12:55 pm » Post: #6 » Download Post
cheers for the info. rear shocks off of a cbr of some type and is fully adjustable(with remote reservoir) so should be able to match the settings up with the forks with some fiddling! i'll check the forks over to see if they have the sp type adjusters. Very Happy
dunkenb
Sat Nov 08, 2008 1:16 pm » Post: #7 » Download Post
just checked and no sp type adjusters.... oh well.
only identifying numbers are k657b-l on the left and k657b-r on the right.
do these refer to anything??
Sat Nov 08, 2008 1:48 pm » Post: #8 » Download Post
i would say they were model refrence numbers
dunkenb
Sat Nov 08, 2008 2:23 pm » Post: #9 » Download Post
ok?...... any idea which though??
Sat Nov 08, 2008 4:16 pm » Post: #10 » Download Post
not sure about that as some twin light h model? import only had usd forks but dont know if their the same as the later models
dunkenb
Sun Nov 09, 2008 8:11 pm » Post: #11 » Download Post
contacted the chap i got them from ,they're H forks.
bad news though...........as my missus paid for them she won't let me have them till crimbo!!!! lol.
Moriwaki-man
Oil seals
Wed Nov 19, 2008 12:49 pm » Post: #12 » Download Post
Sorry for the delay - managed into my spare room today Shocked ( If i posted a photo you would know why !)
Get yourself Ariete # ARI.047 seals they are double or triple lipped and last for ages Smile
Best getting new cir-clips and dust caps too.
MM! Smile
dunkenb
Sat Dec 27, 2008 1:04 pm » Post: #13 » Download Post
well got the forks on, got me away from christmas for a couple of hours! lol
just waiting for my vfr discs to turn up and a zxr front spindle!
had the nsr bearings sleeved up to fit the zxr steerer, got a local engineering firm to do it, only £30!
i'll post some pics up when it's all back together
dunk
dunkenb
Fri Jan 16, 2009 9:51 am » Post: #14 » Download Post
any one know how much oil to put in zxr forks?
i looked on zxr400 world but couldn't find any info on how much?
cheers
dunk.
Moriwaki-man
Fri Jan 16, 2009 2:54 pm » Post: #15 » Download Post
dunkenb wrote:any one know how much oil to put in zxr forks?
cheers
dunk.
Sorry I missed this one D Embarassed
You need to go to the ZXR front page (don't want to hiss Andy off listing link) and not the forum, you'll get a link for the complete Kawasaki workshop manual Cool
Still having problems give me a shout Smile
