The HRC racing harness has no plug for the GPS. I'm not sure the results of unpluging with the stock harness. _________________ 1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Surely this is just a plug to go where the neutral sensor is?
This is something quite fancy on a '21 as the PGM needs to know what gear the bikes in.
On an '18 and '28 it's just a wire, I snipped mine off on the race bike
If that's the case it's of use if you're doing a tidy job on a race bike and don't need a GPS.
Unplug the neutral wire on a stock carded '28 and it won't run in gear (will it Tom?).
It looks the same for a normal loom and PGMIII'd '21 (as the neutral wire goes back to the PGM), on an '18 it just means the neutral light stays on. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Cool, cheers for the info guys I'll be mucking around with her this weekend connecting and disconecting wires and see how she gos. Think I'll spend that couple of bucks on a cheeseburger instead of that plug. _________________ Ride it like u stole it!!!!!!!
