MC16 hone grit
TravisNSR/RS250's
MC16 hone grit
Thu Oct 02, 2008 7:03 am » Post: #1 » Download Post
hello,
I was wondering if anyone could recomend a hone grit for the barrels.
this would be if everything were in working order, using a flex hone ball style to bring it back to a consistent edge and the 45 degree hatches?
thanks for any info in advance, will be much appreciated
Travis
Fri Oct 03, 2008 3:02 am » Post: #2 » Download Post
I use 240 grit
TravisNSR/RS250's
Fri Oct 03, 2008 4:31 am » Post: #3 » Download Post
thanks matt. does any one have a supplier in aus?
andreb
Mon Oct 06, 2008 4:20 pm » Post: #4 » Download Post
I was under the impression you should never hone a NSR cylinder as they are plated and you could ruin them?
And I thought ball hones are never tobe used on ported cylinders since they can change the port shape as the balls pass by the openings?
Wouldn't a bar or flap hone work better?
Andre E. Benguerel
1996 Honda NSR250R
2000 Honda RS250R (NX5)
2008 Honda RS250R (NXA)
AFM Expert #430
Tue Oct 07, 2008 1:54 am » Post: #5 » Download Post
Never had a problem.
andreb
Tue Oct 07, 2008 6:17 pm » Post: #6 » Download Post
myth busted!
Thanks Matt
Andre E. Benguerel
1996 Honda NSR250R
AFM Expert #430
apexxn
Tue Oct 07, 2008 6:37 pm » Post: #7 » Download Post
When I had my cylinders re-plated they were honed when I got them.
andreb
Tue Oct 07, 2008 6:42 pm » Post: #8 » Download Post
Right but they lay it on thick, then hone it to spec. That is different from taking an old used cylinder and running a hone through it. At least I always thought!
I wonder how thick the plating is when new?
Andre E. Benguerel
1996 Honda NSR250R
AFM Expert #430
apexxn
Tue Oct 07, 2008 6:56 pm » Post: #9 » Download Post
True that.
I did have a used cylinder honed the other day after a light seize. Worked out great and is running well.
andreb
Tue Oct 07, 2008 7:42 pm » Post: #10 » Download Post
apexxn wrote:I did have a used cylinder honed the other day after a light seize. Worked out great and is running well.
Good to know. I'll have to get a suitable hone for the kit at the track, just in case...
Andre E. Benguerel
1996 Honda NSR250R
AFM Expert #430
TravisNSR/RS250's
Fri Oct 10, 2008 4:39 am » Post: #11 » Download Post
thanks for replies/input/info. i thought honing is a method of finishing, removing imperfections, removing minimal material? assisting in smooth piston movement and the hatches assist in lubrication. When i rebuild my engine i thought this would be a good idea, of course its gotta be within the spec's/limits.
Also is there many members from perth, western aus?
