Front Wheel Spacers MC18 2J
Sun Aug 10, 2008 7:07 pm » Post: #1 » Download Post
Just changed my front wheel bearings and forgot to note which way 'round the spacers went. Wide or narrow spacer on the left?
mick
Sun Aug 10, 2008 7:23 pm » Post: #2 » Download Post
That's why you should always slide the spacers back onto the spindle whenever you remove it.
Mine has wide on the right.
Sun Aug 10, 2008 7:59 pm » Post: #3 » Download Post
Thanks.
I could see why your brakes failed the other week. I serviced the front master cylinder and calipers this weekend. The fluid in the calipers looked like treacle sponge. I guess that's why your brakes were spongy Laughing
Sun Aug 10, 2008 9:39 pm » Post: #4 » Download Post
The wheel will fit with the spacers inserted incorrectly, but the calipers won't line up on the disk - the wheel will lock up as you tighten the caliper bolts!
apexxn
Mon Aug 11, 2008 9:00 pm » Post: #5 » Download Post
Andy wrote:The wheel will fit with the spacers inserted incorrectly, but the calipers won't line up on the disk - the wheel will lock up as you tighten the caliper bolts!
Should I ask you how you know that. Wink
Tue Aug 12, 2008 2:39 am » Post: #6 » Download Post
Do you really think you need to? Laughing
I'm forever fitting the front wheel the wrong way round! Confused
apexxn
Tue Aug 12, 2008 3:25 am » Post: #7 » Download Post
One of the biggest helps I've had is when I forget how something goes Embarassed I just look at the NSR next to it.
David19
Tue Aug 12, 2008 11:00 am » Post: #8 » Download Post
I tried looking at the one next to it but then took that apart.
Bought a third to copy but have already started to take that apart; where will it all end. Question
At the moment, I am not sure which spacers go with which bike.
