MC16 starting issues
Canuck13
Mon Jun 16, 2008 1:46 am » Post: #1 » Download Post
Hi All
I've a MC16 which starts easy enough, however it only fires on the front cylinder for about 30 secs and then the rear cyclinder kicks in. Any ideas as to why?
nxrsr20
Mon Jun 16, 2008 8:40 am » Post: #2 » Download Post
got your carbies setup correctly? no kinks or things in the fuel line to the rear cylinder?
jeff350lc
Mon Jun 16, 2008 11:50 am » Post: #3 » Download Post
Had the same thing on my old 16. Never worried about it as it ran spot on after that. I fitted new plugs, CDI, coil and cleanded carbs over the time i had it, but still it started on one Cylinder if left for a few weeks. I did wonder if it was a bit low on compression on that cylinder, but it made good power on the Dyno. Confused
Max szeged
Mon Jun 16, 2008 10:45 pm » Post: #4 » Download Post
Mw too man, i found it better if you turn the fuel tap to on for a while before starting her up. also give it 1 to 3 kicks before turning the key helps.
feel the wind
Canuck13
Mon Jun 16, 2008 11:02 pm » Post: #5 » Download Post
cool glad to hear I'm not the only one then
