vapor dash ...easy to fit ????
max350lc
Wed Jun 11, 2008 4:08 pm » Post: #1 » Download Post
anyone done a digital dash on a mc21
martin77
Wed Jun 11, 2008 5:18 pm » Post: #2 » Download Post
I've got Vapor on my NSR 350...(which is half an MC21)
I made a new mount from scratch welded to to standard 21 front frame, along with an RGV idiot light panel. The speedo is perfect and easy to read, though the tacho is slightly less visible though the rpm warning lights which are easier to spot.
Fitting can be fiddly with all the small wires to connect to certain points in the loom, and chances are the speedo wire will need shortening (which is hard with such tiny wires)... I had my loom apart at the time, so it wasn't too much hassle, but otherwise, if you're a competant solderer, then you'll find it logical and easy enough.
Overall I'd recomend it, though it was the best option in my circumstances (Yamaha engine won't work with NSR tacho, no speedo drive etc), but if I owned a 'normal' NSR I think I'd prefer to keep the stock clocks.
Don
Wed Jun 11, 2008 7:37 pm » Post: #3 » Download Post
Funny, I was just looking at those this morning along with the ones from Koso
http://www.kosonorthamerica.com/index_us.html
Does the vapor have a light for night riding?
barryj
Wed Jun 11, 2008 7:52 pm » Post: #4 » Download Post
Do a Google search on the Mychron 3 unit with the weak dollar you can buy one from the US for not much more than a Vapor as long as you avoid the duty Wink
martin77
Wed Jun 11, 2008 8:05 pm » Post: #5 » Download Post
Don wrote: Does the vapor have a light for night riding?
Yes, in fact it's clearer at night than in daylight....
mixalisen
Wed Jun 11, 2008 10:12 pm » Post: #6 » Download Post
Hi...
I've been using AIM MyChron3 Plus for 4 years now in my Racing KTM SMR450 in the Greek Chapionship and i can say that this little thing really helped me to improve my self... It has more data - information that you really are going to use... I recomended it 100%...
If you find one in good price, take it...
Michael
barryj
Fri Jun 13, 2008 8:34 am » Post: #7 » Download Post
Just bought a Mychron3 for my RGV off good old e-bat for £80 odd, there are bargains to be had if you keep an eye open.
max350lc
Mon Jun 16, 2008 12:38 am » Post: #8 » Download Post
thanks for the response
Hung
Mon Jun 16, 2008 4:47 pm » Post: #9 » Download Post
martin77 wrote:I've got Vapor on my NSR 350...(which is half an MC21)
Do you have speedy in your meter?
1996 HONDA RS250
1995 MC28 NSR250 SE red/white/green
1994 MC28 NSR250 sp W/ RS250 engine
mick
Tue Jun 17, 2008 9:14 am » Post: #10 » Download Post
The Vaypor does have speedo on it. Mines just not set up at the moment.
I'd take a pic of the setup but I allready get enough stick about my bike as it is. Laughing
martin77
Tue Jun 17, 2008 4:59 pm » Post: #11 » Download Post
As Mick says..yes it has a speedo pick up. I mounted it from a little bracket on the brake caliper mounting bolt and glued the magnet to the disc carrier....works fine...
