mc21 airbox mod
GrantA
mc21 airbox mod
Sat May 31, 2008 9:00 pm » Post: #1 » Download Post
Would doing the airbox mod on a mc21 be easy enough to do at home?
If so any pictures?
If not who would you recommend?
Cheers, Grant.
Sat May 31, 2008 9:08 pm » Post: #2 » Download Post
Couldn't be any easier... it's like drilling through soft plastic!! Very Happy
20mm flat wood bit -- drill 4 evenly spaced holes in the front slope of the airbox lid. Should be obvious when you look at it!
Short length of duct tape -- for covering two holes on colder days/evenings to richen it back up a little if necessary!
Simple.
DifferentStrokes
Sun Jun 01, 2008 4:18 am » Post: #3 » Download Post
A forstner bit makes a pretty clean hole
80XAR
Mon Jun 02, 2008 1:56 am » Post: #4 » Download Post
If you couldn't be stuff getting a wood drill bit, you can use a small drill and drill lots of holes in a 20mm circle then use the drill like a die grinder to join them all up and smooth it out
Wood drill bit is alot easier though.
