help with pictures of air screw
Max szeged
Wed May 28, 2008 8:49 pm » Post: #1 » Download Post
I am sorry to say this but i cant find where to adjust my air screw. i took off the seat faring but i can only see the black air box. is there an air screw on both side or just one side? a photo would be nice, looked through the manual and still couldnt finde it.
lots of thanks!
feel the wind
lam.666
Wed May 28, 2008 9:31 pm » Post: #2 » Download Post
might help if you list your bike model as well, different carbs for different series i think.
"Working on one carb' at a time, first note the original settings, in case you ever wish to return the carb's to their original state. Screw the air screw in, counting the number of turns carefully. Now unscrew the first float chamber. Push out the float retaining pin and carefully lift out the float. Keep each float and needle with its respective carburettor body. Note that as you remove the float the float needle will come out too. You will be greeted by a view similar to this:"
found that on this link, the way i read it its not in the float bowl, anyone with a pic could enlighten us both.
nxrsr20
Thu May 29, 2008 2:45 am » Post: #3 » Download Post
cool pic....plastic wrapped for sanity Razz
Out of interest, what is the screw that is directly above the the carby bowl drain screw?
lam.666
Thu May 29, 2008 5:00 am » Post: #4 » Download Post
thanks differentstrokes, stupid question though, what does the airscrew do?
Max szeged
Thu May 29, 2008 1:48 pm » Post: #5 » Download Post
thanks for the nice photo and sorrry! Its a mc16. so there are two of them, one on each side? what should i remove to see it? i took off the right seat plastic yesterday but could not get a clean view of the place. or does the carb need to be taken out for adjusting the air screw? manny thanks!
feel the wind
RichG
Thu May 29, 2008 6:59 pm » Post: #6 » Download Post
I don't want to 'hijack' this thread, so Moderators do let me know if I should start a new one.
But on the subject of air screws for the off idle to low rpm range.
I'm having big trouble starting from cold, it will never kick but goes after a (sometimes lengthy push). Once running, I've noticed its very wooly from idle to around 3000 rpm, too much throttle and it wants to bog down, too weak a mixture? From 3000 to 12000 rpm its as crisp as a winters morning. Air screw setting?
A final point, once warm it'll go first kick, or by hand, with no throttle! Confused
Rich
lam.666
Thu May 29, 2008 9:53 pm » Post: #7 » Download Post
thanks differntstrokes that helps heaps ay
max, looks like the airscrew is located behind the fuel line that goes in to the fuel bowl (right nipple/tubey looking thing to the right of the pen), should be on either side of the carb and you should be able to access it with the fairing off, you might have to remove the line or just push it out of the way. should be located just under your airbox by the looks of it too.
but looking at it again.. i cant be too sure
Thu May 29, 2008 10:16 pm » Post: #8 » Download Post
Hmm...
NSR-WORLD jetting guide
Does anyone remember the Main Site even exists?! Rolling Eyes
Max szeged
Sat May 31, 2008 12:53 am » Post: #9 » Download Post
Maybe this is a stupid question, but i am going to ask anyway because i dont know. which carb. is for which cylinder?
feel the wind
80XAR
Sat May 31, 2008 1:59 am » Post: #10 » Download Post
I found my 21 was really painfull down low as well. And hard to start. Hard to take off under 4-5k. I changed the air screws to 2 full turns out (they were 1.5 each before) and it made it much better. Easier to start as well.
I think it would actually be better with another 1/4 turn out but its come into winter over here so the cold air will help with that a little.
The carbs actually line up with the respective cylinder if you look at them from a riding position.
Max szeged
Sat May 31, 2008 4:03 pm » Post: #11 » Download Post
ok so you mean right carb for front cylinder, and left carb. for rear cylinder. or the other way round?
feel the wind
80XAR
Mon Jun 02, 2008 2:16 am » Post: #12 » Download Post
Yes, that is correct
Check the parts manual if your unsure. The pic shows it pretty clearly
Max szeged
Mon Jun 02, 2008 12:30 pm » Post: #13 » Download Post
hell that place is impossible to get to. got my finger there though, feels like somone changed the screw to something else. how could anyone adjust that place with it in situ.
feel the wind
Mon Jun 02, 2008 5:09 pm » Post: #14 » Download Post
With something like this...
Pictured next to a slow jet for size comparison!
Max szeged
Mon Jun 02, 2008 8:27 pm » Post: #15 » Download Post
Thanks Andy pictures are always the best. Everything we do is mostly on visual interface.
feel the wind
